gvr4737
Evo for sale:
Price drop $12,000 firm!! Bring your trailer or dolly
I am Selling My Project Evo Do to a change in Funds right now and Hope New Buyer can get it tuned
All it needs is a TUNE!!! Run 10s!
2005 Lancer Evolution 8 RS ( Asking $14,000)
Car has 89,000 Miles on Body. Title is Labled as a NAM Title but is NJ legal and Legit
Exterior:
Inca Gold Paint job (all door trims, engine bay, etc painted) has some dings and scratches
Real VIS Carbon Fiber Hood and Trunk with 3M Carbon Fiber Wrapped roof
Carbon Fiber air duct vents in front bumper
Enkei RPF1 Rims (17x9) w/ Nitto 555r Drag Radials installed .
All brakes including pads and rotors are good and new
Interior:
Evo 9 Carbon Fiber Dash trim
Carbon fiber trim peices in varios parts of car
Carbon fiber shift knob and covers for most dash peices
2 Sparco Evo fixed position Race seats
( interior was gutted to save weight for drag racing , all interior peices minus rear seat I have)
Evo 8 Fixed Position Brackets on Sparco Seats
Has A Pioneer Headunit Installed and 4 Pioneer Speakers in car ( RS's Did not come with music)
Engine:
2.0L motor, freshened up motor less than 10k ago ( Compression and Leakdown Test Perfec)
Black powder coated valve cover
New mitsubishi headgasket with ARP L19 Headstuds
Mild porting to head with HKS 280/280 cams
Hks Timing belt and timing accesories all new
Full Race Replica T3 Tubular ram horn exhaust Manifold ( largest runners available)
Precision 6262 SP CEA Turbo
Full 3 " unrestricted flow exhaust w/magnaflow muffler
Spoolinup Speed Density Conversion w/4bar map sensor and gm ait sensor
Custom Aluminum Catch Can Setup
ETS Short Route Intercooler piping
Aluminum Evo 5 Aftermarket Radiator
Spearco Intercooler core
PTE 1200 CC Injectors
Walbro 400LPH Fuel Pump
Car has aftermarket Solid Mounts for Engine,Trans,subframe, ETC
(No AC in Car, Short Belt installed)
DriveTrain:
DogBox Stage 2 Transmission (Bought From Previous Owner and showed Receipt for Built Dogbox Trans)
Quartermaster 7.25 V Drive Twin Disk CLutch Setup
Hydro Bearing ( Slave Delete)
New OEM CLutch Master with Steel Braided Lines all round
AMS Aluminum Shifter Cable Bushings and Shifter Base Bushings
All New OEM Axles
Aluminum Drive Shaft Bushings and Aluminum Rear Subframe Bushings
All Diffs have Redline Fluids along with Transmission as well
Car was driven Around Block on stock Fuel setup to make sure everything Was good Mechanically
(Car DOES NOT Run Currently, Requires Someone to Setup ECU for the Speed Density Conversion along with the
injector size and added Fuel. Basically Tow this car from my driveway directly To Your Tuner of choice and car
will put down some serious Numbers)
This Car is in no way in Mint Condition. The body has scratches and few small dings. no Major Damage anywhere
on car, Front Bumper is cracked and has been sticked with zipties. Carbon Fiber hood and trunk are faded,
Require new clear coating
For the price I am asking, The car will put down awsome numbers and track Times and with a little TLC will be a
pretty Awsome Drag Car.
Like i said interior is out of car aside from the two fixed seats, If serious Buyer wants me to reinstall
interior panels I will
my cell phone # is 973-902-9390
My Email Is [email protected]
Car is located in Northern NJ
Exterior:
Interior:
Engine:
DriveTrain:
All New OEM Axles
