Thinking about selling my daily driver VR4. I don't have to get rid of it but I can drive my one of the other family cars instead. Also entertaining trades. Best contact my cell phone is 1-774-274-9247
Details-
1991
Summit white
240k on chassis
120k on engine/rebuilt trans
Gas tank is the best I have ever seen on one of these and the chassis is clean underneath with the rockers and floor having very little to no rust. Some rust on the bottom of the doors but not much.
Specs when I purchased the car that have about 120k miles on them or less
-Engine rebuilt 120k miles ago
-2g pistons/1g rods
-No balance shafts
-Engine assy balanced
-Head was rebuilt with new valves and springs.
-Transmission rebuilt with center diff replaced with a Dogbox Racing bearing upgrade
-Big 16g
-MBC
-K&N filter
-Rewired 255lph
-AFPR
-3g MAF
-BR 2.5" turboback with cat
-Autometer Sport Comp boost gauge
-Cusco front and rear strut bars
-KYB GR-2s with H&R springs
Work recently performed by myself, either new or very good used condition that I have put less than 1000 miles on
Engine/Turbo
-All new timing components
-DKS 264/272 cams
-3g lifters
-ARP Headstuds
-OEM Composite headgasket
-SBR exhaust manifold
-Tial 38mm wastegate
-SS o2 housing
-Oil change
-Emissions delete
-Link 2.5
-New NGK wires and BR7ES plugs
Chassis/Drivetrain
-ACT 2600 with street disc
-Fidanza aluminum flywheel
-SS full clutch line
-New slave cylinder
-OEM clutch fork
-OEM Throw out bearing
-Front brakes
-Outer tie rod ends
-Ebrake cable
Extras-
-PTE 880cc injectors
-Evo 9 GSR enkei wheels
-5 lug conversion parts
-Headlights
The Good-
-Car runs and drives well. I drive it every day and it really has given me no problems. Engine has good compression at 160psi on all 4 cyls. Has had all maintenance performed regularly. Much less rust than a lot of New England VR4s. Interior is in very nice shape with only one little rip on the drivers seat that I will most likely take care of. Sunroof still works and doesn't leak.
The not so Good-
-The paint isn't the greatest. Front bumper is scraped up as well as the front passengers side fender. Passengers side was side swiped prior to my ownership so there is a crease down the side. Really not noticeable in the pictures. Clunk in the front end which will be repaired this week I am hoping. Needs motor mounts but I will have them or have them installed this week as well. Shifter feels notchy and second gear grinds intermittently when very cold.
That is about all I can think of at the moment but I can answer any questions, just give me a call or text. Sorry for the long ad.
Details-
1991
Summit white
240k on chassis
-2g pistons/1g rods
-No balance shafts
-Big 16g
-MBC
-K&N filter
-Rewired 255lph
-AFPR
-3g MAF
Engine/Turbo
-DKS 264/272 cams
-3g lifters
-ARP Headstuds
-SS o2 housing
-Oil change
-Emissions delete
-Link 2.5
Chassis/Drivetrain
-New slave cylinder
-OEM clutch fork
-Front brakes
-Outer tie rod ends
-Ebrake cable
Extras-
-Headlights
The Good-
The not so Good-
