kooter
So I really don't want to sell the jeep. But I am willing to sacrafice it to fund my GVR4.
So lets start with
The bad.
It has jeep rust. Not the worst I have ever seen but it is rough.
Horns have been unplugged due to honking at random times when turning.
Radio power antena broke, has non power antena stuck in the hole. head unit(not stock) has aux input.
Lower dash ends not bolted down. center concole not screw down.
Slight wheel hoppish on hard turns, normal turns no issue.
"PRNDL" trim around shifter. broken.
The good
I have owned this cherokee for just over a year. Got it with about 102,00 miles currently has 103,xxx So I haven't driven it to much. Most miles have been in the last few months.
First thing I did when I got it
New front sway bar links. one was broken. Replaced both.
Shocks all the way around. Stock cheapies from orielly's.
Front brakes including calipers.
Fuel filter
Plugs, cap, rotor
5 brand new goodyear wrangler sr-a 225-75-15
Rugged ridge exhaust manifold exhaust painted, titanium wrapped, high temp silicone coated.Heat cycled. Walker exhaust 2 months ago. Completely replace brand new engin to tail pipe.
Throttle body spacer
Air filter was soaked in oil. All pcv/vent hoses replaced with factory parts. removed valve cover. Lots of sludge. Has been removed and cleaned twice. 3rd air filter has stayed pretty clean. Has had 4 oil changes in the thousand or so miles. Last time was filled with valvoline high milage synth. Bosch long distance filter I believe
Water pump, t stat & housing, fan clutch, all replaced 300 miles ago working great doesn't go above half on temp guage at a stop, while driving it is well under half.
4X4 works great I have used it about a dozen times, As I hear we are supposed to get 5 or 6 inches of snow tonight I will be using it for sure. Honestly this thing is awsome in the snow. It is part time 4 wheel. Only to be used when the wheels are able to slip. You cannot drive around on dry pavement with this 4X4 setup.
I have tried to describe the condition of this cherokee as best as I can. If I have forgetten anything I will add. But I think that is everything.
Lastly I know I have well over the 3500 invested into this jeep. I am not looking for a quick sale and as much as I would love to negotiate I really can't go much lower. As I am trying to fund the vr4 build. I would consider gvr4 part and a lesser cash offer combined. Also consider trade for another GVR4.(glutton for punishment I am)
Feel free to text me (224)388-1517 or pm me with any question's.
So lets start with
The bad.
The good
Fuel filter
Plugs, cap, rotor
