Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 92 Galant VR4 425/1000 Davenport, IA $13000.00 SOLD
Old Balls
425/1000
Galant VR-4 org Post #: 1077361 posted 07/23/12 07:14 PM     Remind Me!  Send Private Message   Edit Post
I have owned this car since Dec of 2003. I started with it as a bone stock car with 113,000 miles at a bank repo lot. I have spent 9 years bringing this car to this point. It is a 9.8(maybe better) out of 10 both inside and out. I am extremely anal and nothing has been left to chance. I daily drove it for 5 years before getting really serious about the restoration. In the last 4 years, it has not seen snow/ice and only got wet to wash it and getting caught in the rain at MOD one year.
I would not hesitate to drive this anywhere. As you can see from the info below. It is running a very safe "street setup" tune of 361whp at only 18psi on Shell 93 octane gas.
I am asking $13,000 firm. That is $2000 less than appraisal value and that was before the interior restoration/dynomat work, EVO III tranny, drive shaft, engine bay, radiator, piping, battery, and ECMlink V3 w/SD setup dyno tuned work.
This car is insured for $20,000 at Hagerty Insurance (costs $400 a year). It is worth every penny.
If you have any questions, email me at [email protected] or PM me here with your phone number and I will call you.
The only "bad" thing, drips about 3 drops a month from the oil pan gasket.
This is one of the best 5 examples in the USA. Below is the exact "Members Showcase" thread with current pictures and examples of what has been done extra.
Body:
New paint by Tom Lindle
Factory Summit White
New emblems
New chrome
White handles
Rustoleum oil based flat black undercoating
Complete engine bay restoration
Looks like a new car
Mods:
Motor Fully built by Class One Inc
2.3L stroker with cryoed and MicroBlue coated bottom end
Stainless Steel O-ringed deck
Eagle rods
JE .40 pistons
ARP hardware throughout
3G lifters
BC 280 cams
Sleeper stock intake mani that has been cut, knifedged, and re-welded
Throttlebodys.com rebuilt 65MM TB
Stock oil pan with -10 drain fittings
Custom 10"x10" oil cooler w/8" fan and -an10 braided lines
PLX wideband O2 with gauge inside cabin
Mitsu timing parts
Rebuilt ported head
Supertech springs
Profain motor mounts
1G style aftermarket Radiator w/twin 12" fans custom setup for 160 degree operation
Fuel
RC750 injectors
255 Walbro pump rewired with 10Ga wiring
SARD AFPR with Marshall mechanical 100psi gauge underhood
Tranny/Driveline
Headdynamics rebuilt tranny and T-case
EVO III spec tranny (double syncros on 1,2,3,&4, close ratio 3/4, the works)
ACT Chromemoly flywheel
Clutchnet sprung 6 puck w/3X PP
Mitsubishi Diaqueen
Brass shifter bushings
TEL shifter
New master and slave cylinders
4 Bolt LSD rear
Red Line Heavy Shock proof in T-case and rear
Complete Drive shaft rebuild using all OEM parts
Forced induction
PTE SC6152RSP A/R .70 ball bearing
FP Race exhaust manifold
JGS external wastegate
Custom stainless steel down pipe (Head Dynamics one-off work of art)
FMIC and piping from Extreme Turbo Systems
Forge BOV (vented to atm)
4 Bar Speed Density
GM Intake Air Temp sensor
4" aircleaner setup with a cold air box
Lower Shores Performance MBC
3" turboback exhaust w/o cat
Brakes/Tires/Suspension
Ceramic pads on all 4 corners
New rotors - 5 lug Stop-Tech cross-drilled/slotted all around
Yingling 215/45/17 ZR Ultra High Performance rubber
Enkie 2 piece OEM rims (won at MOD 08)
Full ABS delete
New flexible brake lines
H&R Galant VR4 specific springs
KYB GR2 struts in rear
Monroe Sensa-trac struts in front
Whiteline front swaybar
Whiteline rear swaybar
Whiteline rear strut tower brace
Cusco front strut tower brace
5 lug hubs
All new OEM wheel bearing/seals/lug nuts/lug studs
Electronics
PLX WBO2
Marshall Oil Pressure gauge
Marshall Fuel Pressure gauge
Marshall Boost/Vac gauge
Marshall Volt gauge
ECU capped and socketed
ECMLink full V3 w/speed density setup
Relocated full size battery to firewall
There is plenty more but this list is long enough.
Dyno graph on 6/14/2011
Video of a second gear pull on 6/14/2011
Pictures taken in July 2009 pics:
Pictures taken in March 2012:
Pictures taken in July of 2011. New engine bay paint, speed density setup, EVO III transmission, new intake piping, radiatior setup, etc...
Pics of some of the custom work done by Chris Beran and other custom work.
Gauges change color with dash lights
Curtis rails (before new undercoating)
Edited by Terry Posten (02/02/13 04:45 PM)
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (50.82.187.169) | Report this post to a Moderator
Flip4G63
Den Mother
1439/2000
Galant VR-4 org Post #: 1077411 posted 07/23/12 11:05 PM     Remind Me!  Send Private Message   Edit Post
i think i just creamed a little.....
glws! worth every penny imo
91 GVR4 1439/2000 White
Posts: 1154 | From: Abilene Tx | Member Since: 08/28/07 | IP: (74.195.35.158) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1077420 posted 07/24/12 12:31 AM     Remind Me!  Send Private Message   Edit Post
Reason for sale?
-Mark
1051
Posts: 11900 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.185.43.218) | Report this post to a Moderator
91_427
427/2000
490/2000
Galant VR-4 org Post #: 1077455 posted 07/24/12 12:34 PM     Remind Me!  Send Private Message   Edit Post
I will trade you my soul and first born for your car. PM if interested.
Posts: 101 | From: South Jersey | Member Since: 04/02/12 | IP: (138.162.128.54) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1077473 posted 07/24/12 02:49 PM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
Reason for sale?
Need new project, anything more this car needs is going to be a "personal choice" and not a need. I am ready to start looking for something else and I don't have the garage space to keep this and another "labor of love".
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (192.43.65.245) | Report this post to a Moderator
rheckert
I Love Wagons
Galant VR-4 org Post #: 1077483 posted 07/24/12 03:20 PM     Remind Me!  Send Private Message   Edit Post
Build a bigger garage. Problem solved.
Next
GLWS Terry!
Family hauler -Yes it has a locking diff.
AWD goodness with 4 doors
Posts: 4115 | From: Indianola, Iowa | Member Since: 03/04/04 | IP: (174.253.135.228) | Report this post to a Moderator
PearsVR4
Galant VR-4 org Post #: 1077585 posted 07/25/12 12:13 AM     Remind Me!  Send Private Message   Edit Post
I hope this car goes to someone as loving as you have been. That's a great looking galant. Just for clarification, there is no radio/audio in there?
| | | IP: (70.162.164.213) | Report this post to a Moderator
jcgalntvr4-244 Galant VR4.org Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 1077589 posted 07/25/12 01:04 AM     Remind Me!  Send Private Message   Edit Post
fucken sellouts...............
1991 JDM Galant Vr4
1991 Galant Vr4 244/2000
1991 Galant Vr4 30/2000
1991 Galant Vr4 142/2000
Yeah Im an addict.......
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (207.177.126.109) | Report this post to a Moderator
Puertorican22
364/1000
Galant VR-4 org Post #: 1077599 posted 07/25/12 08:37 AM     Remind Me!  Send Private Message   Edit Post
What a beautiful VR4 good luck with the sale.
1992 Galant Vr-4 364/1000
Posts: 31 | From: Aurora, Co | Member Since: 04/26/12 | IP: (63.232.201.154) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1077619 posted 07/25/12 10:58 AM     Remind Me!  Send Private Message   Edit Post
Quoting PearsVR4:
There is no radio, but there is a 4 channel amp with IR remote and an Ipod cable (actually has 3 stereo RCA inputs). Connected to the factory wiring for speakers.
Not the best clarity but is decent and works well.
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (204.54.36.245) | Report this post to a Moderator
getboosted
Galant VR-4 org Post #: 1077698 posted 07/25/12 06:43 PM     Remind Me!  Send Private Message   Edit Post
Does it still have working A/C? Very nice and GLWS!
_______________________-
Posts: 135 | From: Charlotte, NC, USA | Member Since: 12/05/02 | IP: (71.75.12.215) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1077713 posted 07/25/12 08:37 PM     Remind Me!  Send Private Message   Edit Post
No AC. It worked fine before I removed it.
Could be re-installed but the radiator and oil cooler would have to be modified.
All electrical for it is still intact.
bustedsm
trying to feel really special
Galant VR-4 org Post #: 1078694 posted 08/01/12 02:51 PM     Remind Me!  Send Private Message   Edit Post
I want this so bad, but I highly doubt you'd be up for a straight up trade with my Typhoon.
2006 Kawasaki ZX-6R 636 - Raw Plasma Candy Blue
Posts: 844 | From: Ripley, Tennessee | Member Since: 11/30/06 | IP: (24.107.113.12) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1078718 posted 08/01/12 05:30 PM     Remind Me!  Send Private Message   Edit Post
No sir. No trades.
Sorry.
bustedsm
Galant VR-4 org Post #: 1078736 posted 08/01/12 08:28 PM     Remind Me!  Send Private Message   Edit Post
Damn, A- for effort I s'pose!
terminitubes
Galant VR-4 org Post #: 1081664 posted 08/19/12 01:43 PM     Remind Me!  Send Private Message   Edit Post
could you txt me a phone number to call about the car, 607-339-1166 -karl
| | | IP: (67.249.199.99) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 1088053 posted 10/02/12 08:22 PM     Remind Me!  Send Private Message   Edit Post
I know you said no trades, but it doesn't hurt to ask. A 1960 mini cooper?
Posts: 199 | From: Lubbock, Tx | Member Since: 01/14/09 | IP: (75.111.172.150) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1088058 posted 10/02/12 09:03 PM     Remind Me!  Send Private Message   Edit Post
It looks like new old stock. Good luck with the sale.
1992 Nile black w/sunroof
Posts: 5836 | From: central Indiana | Member Since: 08/06/02 | IP: (68.58.10.190) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1088073 posted 10/02/12 11:13 PM     Remind Me!  Send Private Message   Edit Post
Quoting Ben:
Sorry, no.
However, post up yor Mini in Anything Goes. I would love to see it.
Ben
Galant VR-4 org Post #: 1088077 posted 10/02/12 11:37 PM     Remind Me!  Send Private Message   Edit Post
It belongs to a guy I work with. He just traded a deuce and a half RV for it. haha
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1088358 posted 10/04/12 06:31 PM     Remind Me!  Send Private Message   Edit Post
This is a great example of a well-restored gvr4. Really wished it had AC a headunit in conventional location, but thats just how would I personally done different!
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15470 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (65.127.129.246) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1088377 posted 10/04/12 08:31 PM     Remind Me!  Send Private Message   Edit Post
I hear you KC. AC is not happening, but I may redo the center console.
Thanks for the compliment, it means a lot coming from you.
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1095287 posted 11/25/12 06:09 PM     Remind Me!  Send Private Message   Edit Post
I really hope this goes to someone who will take care of it. gLWS
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3703 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.83.190) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 1095309 posted 11/25/12 09:59 PM     Remind Me!  Send Private Message   Edit Post
Wow, this is a special car. Good luck with finding a buyer, the effort into this car deserves someone who will continue it.
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (76.6.40.29) | Report this post to a Moderator
2point3
Galant VR-4 org Post #: 1105471 posted 01/29/13 10:00 AM     Remind Me!  Send Private Message   Edit Post
GORGEOUS CAR.
| | | IP: (98.202.215.181) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 7 anonymous users are browsing this forum.
Generated in 0.105 seconds in which 0.061 seconds were spent on a total of 14 queries. Turbo powered.
