SOLD FS: (WI) 1992 Galant VR4 - 544/1000 $3700 OBO
Status
Not open for further replies.
dammitjim
WI
This one is sold.
1992 Galant VR4 #544/1000 for sale. $3700 OBO
Summit White A81 (CD, no sunroof, 1 of 14 click ). 150k miles, clean Autocheck with no accidents, all body panel VIN stickers are original. The paint and body are very nice with no dents and only two small spots of surface rust at the driver's front fender and under the passenger side spoiler mount. The leather including the back of the rear seat is on good shape and has been conditioned. There is a light wear mark on the driver's bolster but no holes. The dash and door panels are clean with no cracks or dings. All the gauges, controls and switches work correctly. The cruise works, the AC does not work. The dash plaque is intact and I have an engraved replica keyfob.
Mechanically the car is very sound. I replaced the timing belt and tensioner recently due to belt wear from contact with an incorrect oil pan bolt. The water pump/pulleys/etc are about 10k miles old. It has new front tire rod ends, ball joints and sway bar end links. The driver's front lower control arm is new because I couldn't get the ball joint out of the old one. The tires have plenty of tread. The trans, transfer case and diff all have new Redline fluid and the transmission shifts smoothly. The brake and clutch fluid have been replaced/bled. The parking brake is disconnected because one cable is broken. The rear KYB shocks are new. The brake reservoir cap has a small tear on the seal and should be replaced. The car sometimes has an inconsistant idle when it is fully warm and the temp gauge is at 12:00. When the temp gauge is at ~11:45 this doesn't happen.
Mods:
16G turbo
2.5" turbo back exhaust
Centerforce DF Clutch
Balance shaft delete
1G rods/2G pistons
Walbro fuel pump
A pillar Boost and EGT gauges
Manual boost controller
Short shift kit
KYB AGX shocks
Ground Control coilovers w/ Eibach springs
dammitjim
WI
If you're not local and want additional pics just PM me and I'll get them to you. I'll add more interior and engine bay pictures soon.
dammitjim
WI
I'd consider trades, what did you have in mind? Not really looking for any major projects, we've got a 3 month old and I just don't have spare time to wrench right now.
4G63_GSR
wis
nice looking car. white and in WI too!
dsmkid
Denver, Co
Quoting dammitjim:
I have a super clean 2001 Montero Sport W/ 140k and runs Perfect that I would possibly be interested in trading. Does your car leak ANYTHING or have any problems at all?
dammitjim
WI
Thanks for the offer but if I get a different car it would likely be something other than a Mitsubishi.
It looks like the valve cover leaks a little but it's not significant. I don't see any spots on the ground where it's parked and as far as I can tell it doesn't have any other leaks.
It's a 20 year old car, it would be a minor miracle if it didn't have any problems at all. I listed several in the first post that I thought were significant. The rear pads are low but still have life left. It has a slight pull to the right. The trunk trim for the back side of the seat is missing. It has a Hyundai oil fill cap. The trunk badges have been removed. There is a scuff on the lower passenger side of the front bumper. The PRESS buttons on the front seat belt latches are faded. The radio display sometimes will only show part of the station number. The antenna doesn't go down all the way. The hood prop stay is broken.
There are probably some other small things I'm not thinking of that are typical of an older car. Overall I think it's very good condition for its age and miles.
4G63_GSR
wis
more interior and engine bay pics. really thinking about this but the talon will have to go first. not sure if i want to let the talon go though.
dammitjim
WI
I added interior and engine bay pics to the 2nd post. Feel free to ask for more. I'll knock $50 off the price if I haven't replaced or recovered the steering wheel before it sells. The spots on the back window are leather conditioner spray. I cleaned them off after taking that pic.
ktmrider
Tempe, AZ
On the A/C thing is it just not engaging or did you remove items?
Interested!
dammitjim
WI
The clutch is missing from the compressor and would need to be replaced for the A/C to work. I have the A/C belt off right now but it comes with the car. Everything else is there. The fan runs when you turn the A/C on inside the car.
4G63_GSR
wis
congrats on the sale. did it stay in WI?
Status
