GVR4 - running list of items to eliminate/convert...
sleepyvr4
Key West
Stage 1 Weight Reduction:
Basic GVR4 stock parts (including engine) to eliminate/modify to reduce weight without compromising safety, emissions, driveability, or anything else "normal"...
1. ABS to non-abs - Click here for how to...
2. Power Steering to 1.8 manual rack, or simply remove all components
3. 4WS (new rear DSM subframe or block off)
4. Cruise Control to DSM 1.8 cable
5. Power Antenna to stubby or shaved/plugged
6. Power Seatbelt to 3 point harness conversion or simply stock lap belt
7. Sounds deadening material removal
8. Power mirror to standard lightweight mirror conversion
9. Aluminum driveshaft(s) installed
10. Stock to Carbon fiber/lightweight hood, fenders, trunklid
11. Stock to lightweight wheels
12. Foglight removal
13. Balance shaft removal
14. Eliminate stock heat shields
15. EGR elimination
16. Lightweight battery
17. Alarm system removal
18. Tool kit, jack and spare tire
19. Stock to lightweight seat conversion
20. Race/Lightweight steering wheel
21. Sunroof elimination (lexan etc)
22. Lightweight flywheel install
23. Intake manifold bracket removal
24. Stock speaker amplifier removal (stereo remains)
25. Wiring harnesses hacked of useless wires
26. Lightweight exhaust (titanium?)
27. Eliminate spoiler
28. Aluminum transfer case install (???)
29. Dashboard hacking/gutting
30. Aluminum/Scirocco Radiator install
31. '92 Center tail light section swap
32. Suspension - save about 25lbs converting to coilovers
33. Under Dashboard Mat elimination
34. Driver's side Motor mount hack
Stage 2 Weight Reduction:
Advanced weight reduction techniques that are "quote unquote" legal/acceptable to some who would still consider the car a daily driver. Many of these cross well over into Stage 3 to some...
1. A/C & all components
2. Heater core/lines
3. Emissions & all related
4. Aluminum bumper install or bumper elimination (some people do this on DD)
5. Timing Cover(s) elimination
6. Stereo and all components removed
7. Remove door crashbars
8. Exhaust down pipe only
9. Eliminate glovebox
10. Stock gas tank to fuel cell
Stage 3 Weight Reduction:
Purely for race intentions - these modifications do not appear daily driver mode at all and compromise everything a daily driver is...
1. Remove all seats except driver's seat
2. Remove interior panels, console, carpet, trim etc.
3. Dashboard removal
4. Lexan to replace all windows
5. Eliminate exhaust
blacksheep
Urbandale, Iowa 50323
1) Interior Wiring harness modification - Remove all ABS, door sensors, auto belt wiring, stereo wiring, heat, AC, relays etc. You will be surprised. I removed about 10 lbs from my evo doing that. I am sure you can do engine bay harness too...
2) Fuel tank - run fuel cell!
3) Dash support beam/ door support beams
How "race" do you want it?
how do you remove the heater core? Thats in the dash correct? so would you have to remove the entire dash before it can be done?
blacksheep
Pretty sure dash has to come off although I havent done it in a gvr4, personally. You have to undo the two coolant lines running in/out the car on the firewall. Same for AC if you are pulling Evap.
sleepyvr4
Key West
Not sure about heater core - may want to keep if car overheats and turning on heater fan is only option...
Balance shafts gotta go /ubbthreads/images/graemlins/wink.gif
CarRacer
Shakopee, MN
Personally I'd keep the timing covers. No sense in letting a rock ruin your day.
I'd add the stock water/oil cooler as well as the water lines going to the turbo. It cleans things up a bunch.
BoostedAWD91
Danville,Pa
if u want to remove the heater core, u have to remove the entire dash. personally i would just leave it in unless its just a track car
One thing I would NOT eliminate.....A daily driver. /ubbthreads/images/graemlins/rofl.gif
TakumiJr
MA
Front seats with some milk crates /ubbthreads/images/graemlins/grin.gif
sleepyvr4
Key West
Quoting CarRacer:
Myself (for about a year on 1746) as well as about 3 dsm friends have been running w/o timing covers for years. One friend rallied a 1g awd auto on several occasions and never had any problems...
1990ggsxnj
Blackwood, NJ
Quoting sleepyvr4:
Quoting CarRacer:
What do you gain out of doing this though??? Besides being able to change the belt without having to take it off.
324vr4
Bozeman, Montana
You can get close to 40lbs eliminating the sunroof too...and its at the TOP of the car where you don't want weight...haha ZAP
sleepyvr4
Key West
Exactly. Change that baby when you change your plugs and oil lol...
throughfaith323
Forked River, NJ
both threads are really good. maybe someone can come up with a list and put things in order of what should be done first. things that are free and things that no one would mind removing. then things for race cars and then things that cost money... also things that are dangerous to remove/chnage.
after that list is compiled another thread can be started as maybe a sticky? i might be interested in starting this list when i get some extra time. hopefully someone else can start it too.
what you guys think?
sleepyvr4
Key West
that's what we can compile here on this thread -
how about 3 sections:
1. basic crap to remove that does not affect driveability or emission laws or safety etc...
2. advanced weight reduction techniques that are "quote unquote" legal/acceptable to some who would still consider daily driver
3. all out race purpose weight reduction mods
I'll compile it up top on this thread...
feedback appreciated - I'll keep adding ideas...
throughfaith323
Forked River, NJ
sounds good to me...i want to come up with more sections to make it more specific maybe after we have a lot of stuff.
like
-safety(removing bumper supports, jack/spare tire etc)
-luxury(cruise, AC, heater core, some interior, PS, etc)
-things you can buy(bumpers, cf hood, cf trunk, flywheel, driveshaft, wheels, seets, under dash, balance shaft elim, glove box, antenna, seat belts/harness, etc)
-emissions(egr,charcoal canister, etc)
-things that prob only a track car would do that would change the car alot(lexon windows, as much interior as possible, etc)
there is absolutely nothing wrong with yours its just that i like to be very specific and this is the type of list i had in mind. it helps so that people know what list they can ignore and what list to look at.
throughfaith323
Forked River, NJ
my bad man i didnt see your list /ubbthreads/images/graemlins/banghead.gif. i like that stage idea. i say you make both cause the stage idea is cool and then if you want to just look right to a specific category you can look at what i had for categorys. know what i'm saying? i def like both tho. nice list /ubbthreads/images/graemlins/wink.gif
