Eliminating 4ws or PS cooler? Power Steering Reservoir Pics
misterfixit
Midlands, UK
just use a non 4ws resevior? then no lines to blank off.
Rich
sleepyvr4
Key West
this post was designated for those who are not as insightful as Mrfixit.
/ubbthreads/images/graemlins/wink.gif
IncorpoRatedX
Arizona
or those that wish to retain their factory power steering fluid level sensor.
If you use a TEL PS resevoir, you cant use the cap from the VR4 with the sensor in place. By blockign that line you retain the use of your "4WS" dummy light (which would in this case simply be used as a 'low fluid level' sensor.
KT
Omaha, NE
Rich
I just picked one up a couple week ago for my swap, but the ports are opposite the Galant, i.e. top and bottom are different sizes than the Galant. So I'm going with the plugs on the stock reservoir. Picks to come.
So you just have to cap off those two lines that are highlighted? One of my rear PS lines is leaking and it is freezing out right now so as a temp fix i'd like to cap it off
MitsuDriver274
Bellingham, WA
The power steering fluid canister off the ggsx and regular galants works great
