FREE mod: short-throw shifter
Luke
San Jose, CA
Simply drill and tap on the shift lever closer to the pivot point.
I moved inwards by about 33% or so, resulting in 33% shorter throw back-and-forth in the cabin.
I used "8mm X 1.25" which matches perfectly with the diameter of the stock pin.
You will also need to make the rubber-stopper thicker in the shifter base. Otherwise, you run the risk of breaking your shift fork when you shifting hard.
I have run with this mod for almost 2 years, and no issue.
mistaVR4
Boulder, CO
Thats pretty cool man! Can you get a pick of the thicker rubber stopper you put in the shift base also.?
Thanks,
-Steve
Luke
San Jose, CA
For the bump stopper on the shifter base, simply cut a small section of a hose and zip tie around the stock stopper to make it thicker.
Like so..
Luke
San Jose, CA
In addition, to install a leather shift boot, you can reuse the bottom portion of your old accordion-style rubber boot.
Like so.
What the shifter looks like:
Thats pretty cool Luke,
How far down the shift lever do you drill the hole. like a 1/2 inch or somthing
Luke
San Jose, CA
I drilled it all the way through, and also tap it all the way through the lever.
Then I use a bolt, a washer, and a nylon lock-nut at the bottom..
I will try to take a picture of this.
The bolt does not clamp down on the shifter bushings.
The lock-nut at the bottom of the lever kinda acts like a jam nut.
