DJ Belize Green GVR4 (737/2000)
This is my first Galant VR4 ever owned so im just using the list of stuff in the car that the guy had in the for sale if nobody minds /ubbthreads/images//graemlins/grin.gif
BODY:
1991 Mitsubishi Galant vr-4
Belize Green
JDM E39a Front End conversion w/ Projector Foglights
93 LS Headlights with retrofit HID’s
JDM Sidemarkers in Amber
Carbon Fx OEM Carbon Fiber Hood
Carbon Fiber OEM wing
JDM wind/rain deflectors
SUSPENSION/WHEELS
Eibach Ground Control Coilovers
Prothane Sway bar bushings/endlinks
Enkei Evo 5 Rims 17 x 8 wrapped w/ 225 45 17" Continental Extreme Contact Tires
3000GT Vr-4 Aluminum 4 piston Calipers
R1 Concepts Drilled/slotted 99 vr4 Rotors
Custom Steel Conversion Brackets for the Brake Set up
ENGINE/POWER
4G63T 2.0L 16v DOHC
1G Big Rods/2g Pistons
Mitsu 4 layer head gasket
ARP Head Studs
Mild Ported head
SCM-6152E Turbo
2G Ported Exhaust Manifold
2G 02 housing fully ported
Full 3 inch Turbo Back exhaust
Custom Fuel Rail w/ -10 AN
Aeromotive FPR
2G Maf
DSMchip Tuned Ecu
S-afc2 Fuel Management
Coil On Plug Ignition
Fully Built Transmission , Double Syncro’s strengthened Gears
Built 4 bolt LSD Rear upgraded bearings/ new ring/pinion
Rebuilt Driveshaft, new carriers.
HERE ARE SOME PICS
