Vman911
Engine Mods:
6 Bolt block (bored .40)
Wiseco Pistons (9:1:0 comp)
Eagle rods
ARP Mains & Head Studs
272 Cams (Regrinds)
Evo8 springs & retainers
OBX Cam Gears
Aluminum Intake
Cometic Head Gasket
Aeromotive FPR w/ 6an lines from tank to rail
255 Walboro Fuel pump
Custom Coil-on-Plug setup
DNP S.S. Manifold w/O2 housing
FP Green Turbo (730CFM)
FIC 680 Injectors
Evo8 Maf
DSM link V3
Turbo XS Boost controller
Tial BOV
Tial 38mm Wastegate
Power Core FMIC w 2.5” pipes
Throttlebody Bored to 63.5mm (stock,58mm)
Drive Train mods:
Rebuilt Tranny w/ Evo3 HD input shaft, Evo3 First Gear
Dual 2nd gear syncro setup
Custom 6 puck sprung clutch, 2100 lb P-plate
Short Shifter w/ Bushings
Act lightened Flywheel, 11lbs
4 Bolt LSD Rear End
Interior mods:
Evo8 Steering Wheel
Evo8 seats F & R
HKS turbo timer
Autometer gauges (Oil, A/F, Boost, Temp)
White Face Guages
Exterior mods:
20% tint
Power folding mirrors (JDM)
17” Axis rims
KYB struts F & R
Sportline lowering springs w/ 1.5” Drop
3000 GT-VR4 Calipers (Front)
Cross Drilled / Slotted rotors 12.5” in front & 10” rears, HPS Pads
Polyurethane Subframe Bushings (rear)
8.5K HID's
Eagle rods
272 Cams (Regrinds)
OBX Cam Gears
Aluminum Intake
Cometic Head Gasket
FIC 680 Injectors
Evo8 Maf
DSM link V3
Tial BOV
Tial 38mm Wastegate
Drive Train mods:
4 Bolt LSD Rear End
Interior mods:
Evo8 Steering Wheel
Evo8 seats F & R
HKS turbo timer
White Face Guages
Exterior mods:
20% tint
17” Axis rims
KYB struts F & R
8.5K HID's
