EBAY COMP CAM 101100 ..99 No reserve
jnava
Arlington, Tx
> click
Brand COMP Cams
Manufacturer's Part Number 101100
Part Type Camshafts
Product Line COMP Cams Quiktyme Camshafts
Summit Racing Part Number CCA-101100
UPC 36584087328
Cam Style Hydraulic roller tappet
Intake Duration at 050 inch Lift 204
Exhaust Duration at 050 inch Lift 204
Duration at 050 inch Lift 204 int./204 exh.
Advertised Intake Duration 254
Advertised Exhaust Duration 253
Advertised Duration 254 int./253 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.407 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.391 in.
Valve Lift with Factory Rocker Arm Ratio 0.407 int./0.391 exh.
Computer-Controlled Compatible Yes
Valve Springs Required Yes
jnava
Arlington, Tx
I spoke with comp cam tech advisor and after giving all the marking he told me the specs that are listed are correct.
jnava
Arlington, Tx
Relisted on Ebay with a .99 cent No Reserve type of BUMP
Brunoboy
San Bruno,CA Home of SFO
so what is this? a 264? or 272?
3rdstrikedsm
32159, FL
These are good cams for the money.
Brunoboy
i still dont understand the numbers, what do they equal to?
jnava
Arlington, Tx
After doing some research a few weeks ago....they are compared to 264's. Some indicated that the specs are FP1's. I dunno how true this is but I've found them over and over again.
click me
I'd say what you have are the comps that FP had them make. There extreme energy as they call them and probably close or equal to the 1's or a 264. If comp would release numbers equal to the import market instead of chevy mentality they'd sell alot more cams I'm sure.
