FREE: Bumper, AC & Fan parts [GONE]
mooserage
Seattle, WA
Have some free parts:
Picked up! -AC Parts, see picture, only item not pictured is the compressor bracket
Note: AC has not worked on the car for about 8 years, was disconnected due to a bad compressor bearing, most AC parts had good seals and a little oil when pulled
Gone! -OEM fan with broken shroud, motor and resistor worked great despite broken shroud
Picked up! -Summit White USDM front bumper in rough shape (some scrapes and cracks on the bottom), but didn't sag and has straight slats still. Has the core cut to fit the ETS FMIC.
Gone! -OEM intake manifold and bracket. One broken bolt in the throttle cable mounts.
Everything is free picked up or plus the cost of shipping. If no interest I will recycle these parts when I get to it.
Thank you.
turbofonz
Granby, MA
I'd take the condenser and compressor + lines. Figure out the shipping costs.
WaRrIoRs16
Ferndale, WA
I'd like the front bumper but not enough to drive down to Seattle just for it. I'll be passing through Feb 21st if you manage to hang on to it until then.
slugsgomoo
Tacoma, WA
in the off chance that it's not already gone, can you weigh the a/c bits that live under the dash? /ubbthreads/images/graemlins/laugh.gif
mooserage
Seattle, WA
Underdash core is 5lbs 2oz. I didn't have the plastic on it since that is still in the car.
Some parts still around as I haven't made it to a recycler. Front bumper is currently pending pickup.
jmorri15
Kemp, TX
Hey Man
I got furloughed and it has given me time to try and figure out what is wrong with the cooling system on my car, looks like I have a pair of bad resistors, a bad fan and a bad relay. If I could get your fan and any other parts of the cooling electronics you might have that would put me on the right track. Let me know how much shipping would be and I'll send it over.
Thank you
