Galant VR-4 Forums » Marketplace » Parts For Sale » FS: '91 Gvr4 Partout (1335/2000) NB *Updated June 19, 2020
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1219532 posted 10/31/15 10:28 AM     Remind Me!  Send Private Message   Edit Post
FS is nearly everything from a 1991 Galant vr4 badge number 1335/2000 with 216,909 miles.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions. I accept all payments via PayPal to: [email protected]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
ENGINE
*GM Alternator part no P8107-3 (Advance Autoparts) $80.00
Throttlebody Elbow $8.00
Engine Lift Bracket $10.00
Rear Upper Timing Cover Tin $15.00
Rear Lower Timing Cover Tin $15.00
Fuel Feed Line $8.00 w/ Banjo Bolt
Fuel Rail $15.00
Fuel Pressure Regulator $15.00
Fuel Filter Bracket $3.00
Engine Mount Bolt (Driver Side) $4.00
ECU Harness Retainer $2.00
Charcoal Canister $15.00
EGR Valve $15.00
Radiator Fan $15.00
Water Pump Pulley Set $15.00
Tensioner Hardware $2.00
BODY
Front Horn Set $12.00
Panel *Locate on Passenger Frame Rail $3.00
Fender Bolts $3.00
Front Side Windshield Trim $20.00 each
Wiper Arm Linkage $30.00
Front Driver Dogleg $40.00
Door Hinges $5.00 each
Door Pin Set $1.50
Alarm Horn Relay $3.00
Wiper Arm Set $30.00 or $15.00 each *Wiper Foil sold
Air Inlet (Passenger Side) $8.00
Coolant Overflow Bottle $20.00
Coolant Overflow Bracket $5.00
Radiator Overflow Line $2.00
Radiator Bracket $8.00
Exhaust Hanger Set $25.00 or $5.00 each
Hood Latch $15.00
Hood Hinge Set $20.00 or $12 each
Hood Bumper Set $3.00
Hood Bumper $1.00 for pair
Cowl Trim (Driver Side) $3.00
Cowl Hardware $1.00
Air Guide Panel $3.00 each
Hood Release Cable Guide $8.00
Fuel Filler Door $15.00
Fuel Filler Door Hook $2.00
Fuel Pump Wiring Cover $5.00
Trunk Dampener $1.00
Plugs, Trunk $.50 each
Trunklid Striker $3.00
Rear Bumper Support Bracket Set $15.00
Trunklid Weatherstrip $20.00
License Plate Light Set $15.00
HVAC
Blower Motor Assembly $40.00
HVAC Vent part no MB439025 *Below Glove Box $15.00
Interior
Instrument Cluster Mount $15.00
Datalogger Cable $20.00
ETACS Computer $40.00
Interior Front Window (Headliner Strip $20.00
Headliner Handles $5.00 each
Interior Weather Trim (Driver, Front) $20.00
Interior Weather Trim (Driver, Rear) $20.00
Interior Weather Trim (Passenger, Front) $20.00
Interior Weather Trim (Passenger, Rear) $20.00
Foot Rest 8.00
Gas Pedal $20.00
Dash Speaker Cover $8.00 each or $15.00 for pair
Defroster Switch $20.00
Horn Pad $15.00
Front Lap Belts $20.00 each
Retractor Mounting Bracket $15.00
Retractor Bracket $8.00 each side
Automatic Seatbelt Trim A. $3.00 each
Automatic Seatbelt Trim B. $12.00 each
Control Unit Auto Seat *Part No MB617345 $20.00
Air Vent $3.00 each
Air Vent Tab $1.00 each
HVAC Control & Stereo Brace $15.00
HVAC & Stereo Lower Brace $5.00
Amplifier Power Adapter Part no MB 665345 $25.00
Buzzer $3.00
Dome Light $30.00
Sunroof Wiring Harnes part no MB665197 $20.00
Sunroof Felt Trim $30.00
Sunroof Adjust Plates $4.00
Sunroof Relay $5.00
Sunroof Control part no MB543075 $15.00
Kick Panel (Driver Side) $15.00
Interior Door Handle Pull $12.00 each
Interior Door Handle Backing $3.00 each
Door Card Clip $1.00 each
Door Ajar Switch $4.00 each
Window Switch $10.00 each
Clutch Interface Switch $8.00
Clutch Switch $8.00
Stop Light Switch $5.00
Brake Pedal Spring $1.25
Rear View Mirror Cover (Passenger Side) w/ hardware $5.00
Doorcard Lights $5.00 each
Door Sill, Rear $12.00 each
Door Sill, Front $12.00 each
Manual Transaxle Shift Lever Panel $8.00
ECU Tray $15.00
ECU Harness Retainer $3.00
Stopper (Glove Box) $2.00
Glove Box Frame $8.00
Glove Box Latch Bar $8.00
Glovebox Reinforcement Bracket $3.00
Glove Box Striker $5.00
Ashtray, Rear Doors $5.00 each
Console Side Trim $15.00 each
Seat Trim Cover $3.00 each
Rear Wiring Harness Retainer (Passenger Side) $5.00
Seatback Trim A. $8.00
Seatback Trim B. $8.00
Trunk Access Trim $8.00
Trunk Dome Light $8.00
Trunk Trim $20.00
DRIVELINE
Shift Cable Selector $12.00
Shifter Cable Clip $1.00 each
Clutch Line to Slave Cylinder Hard Line $5.00
Rubber Clutch Line $3.00
Flywheel Bolt Set $3.00
Pressure Plate Bolt Set $2.00
Reverse Sensor $15.00
Front Differential $80.00
Driveshaft Hardware Set $3.00
Suspension & Steering
P/S Rack Bracket $15.00
Power Steering Reservoir $20.00
Power Steering Reservoir Bracket $8.00
Cruise Control Cable Guide $2.00
Lugnut Set for 2 Sides $15.00
P/S Return Tube $15.00
Rear Strut Mount Cover $5.00 for the set
Rear Shock Lower Mount Hardware Set $2.00
3 Bolt Cups $20.00 each
Rear Wheel Hub (4 Lug) $50.00
Rear CV Axle Hardware Set $5.00
Rear Subframe Stud $15.00
Rear Swaybar Bracket $12.00
BRAKES
Rear Brake Caliper Bracket $12.00 each
ABS Hydraulic Unit $75.00
ABS Computer $40.00
ABS Proportioning Valve $20.00
ABS Connector Bracket $3.00
Rear ABS Wheel Speed Rotor $10.00
G-Sensor (Front) $20.00
Emergency Brake Cable Retainer $3.00
Edited by pot (06/27/20 04:57 PM)
Posts: 1524 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (2606:a000:51a8:1) | Report this post to a Moderator
91galantvr4_4WS
579/2000
Galant VR-4 org Post #: 1220001 posted 11/10/15 06:14 AM     Remind Me!  Send Private Message   Edit Post
I sent a PM and an e-mail since my last one never got to you.
1991 Talon TSI AWD
1991 Galant VR4
2008 Pontiac Grand Prix
1997 Ford F250 HD
Posts: 29 | From: Salem, IL | Member Since: 01/03/15 | IP: (75.129.247.5) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1220062 posted 11/10/15 10:42 PM     Remind Me!  Send Private Message   Edit Post
Hey do you have the driveshaft????? Let me know
"Money doesn't sleep, so why should I"
^ the rotary guy who doesn't know anything about pistons lol
Posts: 42 | From: Chicago, IL | Member Since: 09/03/15 | IP: (107.77.89.19) | Report this post to a Moderator
johnnyRacer
Member +++
50/2000
Galant VR-4 org Post #: 1220392 posted 11/15/15 08:29 AM     Remind Me!  Send Private Message   Edit Post
Do you have the throttle body bolts? What you want for em?
91 GVR4 SW 0050/2000 -sold
-3gMAS/K&N,680cc,BSE,chip,255lph,3"Exh(no cat),H.MBC,evo8/tein-S
87 Conquest TSI
92 Mustang LX Convt-sold
95 BMW E36 Convt-sold
13 F-150 Coyo
Posts: 776 | From: Chicago | Member Since: 01/09/05 | IP: (70.194.71.50) | Report this post to a Moderator
Scientist
Secretary of the Interior
Galant VR-4 org Post #: 1220466 posted 11/16/15 01:12 PM     Remind Me!  Send Private Message   Edit Post
Hi Pot it's me again....
Need the following:
Trans to Engine bolts
Engine Mount bolts
Front cross member
May need more as I continue to put my car back together and find out whats lost or stolen
1988 VR4....Needs a lot of TLC
Posts: 531 | From: Roseau/Dominica | Member Since: 01/18/07 | IP: (199.189.115.30) | Report this post to a Moderator
galantgti
Galant VR-4 org Post #: 1221347 posted 12/06/15 09:28 AM     Remind Me!  Send Private Message   Edit Post
No rear calipers available?
1989 Galant GTi-16v White 145hp
1992 Galant GTi-16v Black 144hp RIP
1978 Buick Skyhawk 3.8 V6 110hp RIP
1997 Galant GLXi 136hp Green RIP
2000 Opel Omega 2.5 V6 Irmscher 208hp RWD
1991 Galant GTi-16v Dynamic 4 (4ws/4wd) 4g63T 220hp
Posts: 92 | From: netherlands | Member Since: 06/19/15 | IP: (84.84.197.110) | Report this post to a Moderator
Galant VR-4 org Post #: 1221348 posted 12/06/15 11:04 AM     Remind Me!  Send Private Message   Edit Post
ARP Headstuds *Used $40.00 shipped to 11779
pm me thanks
Posts: 1489 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.56.49) | Report this post to a Moderator
Galant VR-4 org Post #: 1221365 posted 12/06/15 06:42 PM     Remind Me!  Send Private Message   Edit Post
Thanks. Payment sent.
Posts: 1489 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.29.113) | Report this post to a Moderator
GSXftw
1722/2000
Galant VR-4 org Post #: 1223291 posted 01/26/16 02:57 PM     Remind Me!  Send Private Message   Edit Post
I need the trunk/fuel door opening levers that are on the drivers floor, along with the fuel door latch (the part that opens from the cable being pulled)how much?
1722/2000- Burn victim rescue
91 GSX- 11.66 @ 126 donated to save ^
97 TSI AWD - daily
97 GST- 14.7 @ 100 *sold*
82 Supra 7mgte- 12.66 @ 116
77 Camaro- 12.9 @ 107
Posts: 112 | From: medford, OR | Member Since: 12/22/14 | IP: (68.185.2.34) | Report this post to a Moderator
TurboDSM
1193/2000
Galant VR-4 org Post #: 1223998 posted 02/09/16 05:59 AM     Remind Me!  Send Private Message   Edit Post
Sunroof car?
Matt
91 GVR4 1193
07 cts-v
06 s60r
Posts: 61 | From: Merica | Member Since: 03/07/12 | IP: (198.208.72.13) | Report this post to a Moderator
TurboDSM
1193/2000
Galant VR-4 org Post #: 1224353 posted 02/17/16 05:52 AM     Remind Me!  Send Private Message   Edit Post
Would you be willing to do a roof cut? From the 5" down on all the pillars? How much would that be including the headliner, and all sunroof components?
Matt
91 GVR4 1193
07 cts-v
06 s60r
Posts: 61 | From: Merica | Member Since: 03/07/12 | IP: (198.208.72.30) | Report this post to a Moderator
TurboDSM
1193/2000
Galant VR-4 org Post #: 1224498 posted 02/21/16 08:56 AM     Remind Me!  Send Private Message   Edit Post
Messaged
Matt
91 GVR4 1193
07 cts-v
06 s60r
Posts: 61 | From: Merica | Member Since: 03/07/12 | IP: (2601:402:501:f4c) | Report this post to a Moderator
Kibbeevr4
Newbie
Galant VR-4 org Post #: 1226110 posted 03/30/16 10:11 PM     Remind Me!  Send Private Message   Edit Post
How much for both front quarter panels?
Posts: 0 | From: parker | Member Since: 03/19/16 | IP: (75.71.127.123) | Report this post to a Moderator
Pano
Newbie
Galant VR-4 org Post #: 1226307 posted 04/03/16 10:26 AM     Remind Me!  Send Private Message   Edit Post
I would like the passenger tailight. PayPal ready if still available
Posts: 9 | From: New York | Member Since: 04/01/15 | IP: (2600:387:5:806::) | Report this post to a Moderator
dave
Newbie
Galant VR-4 org Post #: 1226693 posted 04/12/16 09:25 PM     Remind Me!  Send Private Message   Edit Post
right abs Sencor still have it
Posts: 9 | From: Brooklyn ny | Member Since: 02/05/12 | IP: (67.86.157.37) | Report this post to a Moderator
AlinaVr4
Newbie
985/2000
Galant VR-4 org Post #: 1226703 posted 04/13/16 12:41 AM     Remind Me!  Send Private Message   Edit Post
Sent you a text, need a couple of parts bro
1991 Mitsubishi Galant Vr4 985/2000 - WIP
1995 Eagle Talon Tsi AWD - 446 awhp [email protected]
1990 Eagle Talon Tsi AWD - 397 awhp [email protected]
1990 Mitsubishi Mirage AWD - 500 awhp [email protected]
Posts: 7 | From: San Lorenzo, PR | Member Since: 05/15/15 | IP: (24.138.193.29) | Report this post to a Moderator
BAMFTalon
Newbie
Galant VR-4 org Post #: 1229333 posted 06/18/16 12:48 AM     Remind Me!  Send Private Message   Edit Post
need throttle body elbow and front passenger dogleg if available.
Life is too short to drive boring cars...
Posts: 15 | From: San Jose, CA | Member Since: 05/28/14 | IP: (99.104.124.171) | Report this post to a Moderator
Gsxhybrid
Newbie
Galant VR-4 org Post #: 1230472 posted 07/21/16 11:04 AM     Remind Me!  Send Private Message   Edit Post
Still have Cruz control?
93 Eclipse GSX 2.4L gt3076r Power
92 Talon TSI Wife's Toy
91 Talon TSI Stock Daily
90 Eclipse GSX Stock Daily (Wife)
92 Galant VR4 Soon to be daily
Posts: 6 | From: Nevada | Member Since: 10/25/15 | IP: (2607:fb90:2776:f) | Report this post to a Moderator
collinswm
Newbie
922/2000
Galant VR-4 org Post #: 1231334 posted 08/27/16 09:13 PM     Remind Me!  Send Private Message   Edit Post
Is steering wheel still available?
Posts: 2 | From: Cheyenne, WY | Member Since: 08/01/13 | IP: (2600:100e:b016:a) | Report this post to a Moderator
11secDSM
Newbie
33/1000
Galant VR-4 org Post #: 1234809 posted 01/13/17 07:02 PM     Remind Me!  Send Private Message   Edit Post
Do you have a front bumper available from any of your cars?
Posts: 8 | From: PA | Member Since: 08/28/16 | IP: (2601:46:4000:abc) | Report this post to a Moderator
dave
Newbie
Galant VR-4 org Post #: 1235191 posted 02/07/17 10:31 AM     Remind Me!  Send Private Message   Edit Post
sup i send the money i think the name on paypal is karry put dave callender if you can same address thanks
Posts: 9 | From: Brooklyn ny | Member Since: 02/05/12 | IP: (67.82.102.68) | Report this post to a Moderator
dave
Newbie
Galant VR-4 org Post #: 1235192 posted 02/07/17 10:43 AM     Remind Me!  Send Private Message   Edit Post
may need the right abs sensor
2002jm
Newbie
Galant VR-4 org Post #: 1235534 posted 02/26/17 06:57 PM     Remind Me!  Send Private Message   Edit Post
Do you have the radio?
jm
Posts: 5 | From: boise idaho | Member Since: 02/24/17 | IP: (174.27.10.18) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1235543 posted 02/27/17 09:14 AM     Remind Me!  Send Private Message   Edit Post
I have the cd player
Posts: 43 | From: Baltimore, md | Member Since: 04/18/16 | IP: (2601:143:4202:9a) | Report this post to a Moderator
luis84one
652/2000
Galant VR-4 org Post #: 1235626 posted 03/02/17 06:08 AM     Remind Me!  Send Private Message   Edit Post
Engine bay wiring harness?
Posts: 128 | From: lynwood, ca | Member Since: 08/19/09 | IP: (2607:fb90:4ae3:7) | Report this post to a Moderator
Pages: 1 | 2 | 3
0 registered and 30 anonymous users are browsing this forum.
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Generated in 0.097 seconds in which 0.067 seconds were spent on a total of 14 queries. Turbo powered.
