VR6Eater
Well another one is totaled. Car got hit on the left side and the rear door won't open. Rocker panel is pushed in, quarter panel is dented, fender damage, driver's door, front dog leg, and drivers door plastic is messed up. Just did a Felpro head gasket on it a month ago. Wife drove it for 2 days and it got hit while she was at work. Still runs and drives though. Motor and trans have approximately 16,000 miles on them. Have build sheet from Jacks to prove it. I did the head gasket because I had no compression in cylinders 1 and 2. The 4 layer cometic HG was burnt through. No damage was done to the head or block. Found couple loose head bolts though. Does have studs and not bolts which is good. Put it all back together and ran great. Haven't checked compression though. I will as soon as I can get to it. If there is anything you need let me know. Local guys are welcome to come by anytime for parts. I would like to have this done before snow comes.
Here is the add when I bought it.
Here's the damage.
Here's the damage.
