SOLD: 4G63T 2.0L Fully built
Bonezilla
Walnutport PA
BLOCK
2.0L 4G63T 6 bolt
.20 over Manley Pistons ceramic and teflon coated
Eagle rods oil resistant coated
FFWDconnection Butcher Crank oil resistant coated
Pro-gram billet main caps
Race bearings all oil resistant coated
Brand new OEM front case, oil pump, timing components...
Balance shaft elimination kit
Oil Squirters blocked off
SCE Titan copper headgasket with built in o-rings
ARP L19 head studs
Fluidamper crank pulley
Ebay oil pan...tried to save money, will never do that again. A lot of modifying for proper fitment, but it worked
Welded -16 AN fittings on water pump and T-stat housing
Every single bolt is brand new from Mitsu
HEAD
One-off AMS CNC ported head
BC valvetrain: springs and retainers, oversized valves, bronze valve guides, low-boy valve seals ect.....
HKS cam gears and Timing belt
BC Cams 288/288
All assembly done by AMS Performance
LONG BLOCK $4000
Thank you for the space.
5OF2k
colorado springs, colorado
Daaaayyyuummm!! That is one hell of a build. What's the static compression ratio? GLWS, sir. What's the reason for the part out, if you dont mind my asking?
Bonezilla
Walnutport PA
Quoting 5OF2k:
Thanks. Compression ratio is 9:1. I have about 12-14K into this thing already and its about half way done. I estimated another 15K to finish it they way I would want it and I just can't see myself dumping that kind of money into this beast. I guess you can say I lost interest. I also just bought property and building a home so I rather see the money go towards that instead. And, of course, I cant stay away from Mitsubishi's, so there will be an Evo in the garage as well. LOL /ubbthreads/images/graemlins/grin.gif
As for the oil pan, I believe it is an OBX eBay special. Only thing I cheaped out on and kick myself in the ass for doing so. I modified it to make it fit right, removed the spring loaded baffle plates that were inside. Imagine that coming apart and going through your $7000 motor...not cool. And welded some AN fittings on for the oil return. Should have went stock pan, but I was ok with the outcome after modifications so I used it.
ronnycordova
Muncy, PA
Pretty similar to what I have sitting in my kitchen getting built. We differed a bit on the valve train though. I have to ask, where did you get that front timing cover from? The OEM one I ordered is grey or did you just paint that one?
Bonezilla
Walnutport PA
No its not painted. If I remember correctly, you have to order a GVR4 specific cover. I believe the eclipse/talon/laser ones are grey. But don't quote me on that, its been awhile so I don't know if that is correct. Someone else can chime in if they know.
Bonezilla
Walnutport PA
Bump. EMX5636-I see you are into the quad scene. I have a modified 400ex and always willing to hit the tracks. Another buddy of mine has an Ltr450 and we venture to breezewood and some other local tracks. If you ever want to ride, hit me up, always down to ride. 484.239.5325
Bonezilla
Walnutport PA
BUMP for surviving the Apocalypse. Xmas special! $4200 until the new year. Need this gone.
2000GTX
Milwaukee, WI
Oh how I wish it were about 3 years from now. I would be all over this thing.
Good luck until then, pal.
