FS: Go Fast Pieces and some stock stuff
Boostin21
Wisconsin, USA
I need to move these parts so shoot me reasonable offers. They seriously need to go...
-Holset HX-52, this is a big boy turbo that flows well over 90lbs/min. Needs rebuild. $200 obo
-1g/2g AWD 4"-3" V-Band Downpipe, it starts at 4" off the turbo and flares down to 3" under the oil pan so that it'll be more compatible with a wider variety of exhausts. $300 obo
-Megan Racing 1g AWD 3" Catback. Mint Condition. $250 obo
-Vibrant Performance Universal Catch Can. Aluminum. Can be used in upright or horizontal formats. Sight tube included. Brand New In Box!! $90 obo
-(2) JM Fabrications Small Catch Cans, with -6AN fittings installed, come with pushlock lines. Evac those crankcase gases PROPERLY! $130 obo
-4" Stainless Intake. Relocates filter to factory side mount intercooler location for clean and cold air. Has fitting mounted for AN line to run with catch can setup. Makes a HUGE difference! $110 obo --- BUY WITH CATCH CAN SETUP AND WE CAN WORK OUT A DEAL!
-3" IN/OUT DynoMax Bullet Muffler, sraight thru. nuff said. $80 obo
-2g DSM Cylinder Head, low miles and very very clean. $200 obo
-EVO 8 Cams, these can be degreed properly to run on a DSM and since they are hollow they have less rotational mass, not to mention they have a larger duration than stock DSM cams. $100 obo
-2g Intake Manifold, clean. Comes with sensors. $35 obo
-2g Fuel Rail. $40 obo
-(2) 1g Intake Manifolds. Cleaned. $40 each
-1g Big Rods, low miles, in good shape. $50 obo
-NPR 2g Pistons with rings and pins. New In Box. $90 obo BUY WITH 1g RODS FOR A SOLID BOTTOM END!!
-TransDapt Dual Oil Filter Housing/Cooler Relocation. This houses 2 oil filters and is setup for -AN lines so you can remote mount your filters for extra clearance and still run a cooler if need be. Or use for added trans filters! $40 obo
-1g Datalogger setup, includes palm pilot and logging cable. Will need software loaded which can be done for free. $60 obo
-Turbo Gaskets, wide assortment, both hot and cold side gaskets. $30 obo
-92-94 7-Bolt Timing Belt Tensioner. Never used. $80 obo
-22 Spline Transfer Case with 88k on it. $50 obo
-Black Prothane Motor Mounts for 5 Speed 1g AWD, Just idle time/base tune time on these and all the sweat work is done so these are installed and ready to rock! $120 obo
-Sparco Universal Shift Knob. $50 obo
-Aeromotive a1000 Adjustable Fuel Pressure Regulator with Gauge. $140
-Aeromotive Fuel Filter -8AN. $50
-Suzuki Hayabusa Individual Throttle Bodies. Tell your Honda or AE86 buddies, these are awesome ITB's and have a new TPS already! $200 obo
Not really looking for anything unless its a Borg Warner Turbo (s300), Twin Scroll T4 mani, aluminum driveshaft (2g), upgraded axles (1g).
Cullen
Boostin21
Wisconsin, USA
To The Top
Boostin21
Wisconsin, USA
Bump
HOLSET is SOLD!
Really need this stuff gone, please shoot me offers!
VR4Scott
Orlando, FL, USA
Pics of Vibrant catch can and 4" intake please.
Jesus_Negros
USA
You have pics of the ITB's and how big are they?
