FS: DSMpartout spring cleaning - aftermarket parts
NateCrisman
Blairstown, NJ
<b>PLEASE PLEASE PLEASE Email</b> [email protected] <b>DO NO SEND PM</b>
Ross pistons, Eagle Rods, Jay Main caps, ARP mains, matching 6bolt block machined for the pistons. Basically needs a good crank, bearings, and assembly. $750
Drilled rotors sets - (F&amp;R) for 2g awd $100
Slotted rotors - rear awd 1g $50
EBC red brake pads (F&amp;R) for 90-92 AWD w/ single piston fronts $50 (need to be wiped off clean..sorry for dirty pic)
Blitz turbo Timer w/ 1g harness $50
Autometer C2 AF gauge $20
CD player Headunits OBO I have 4 on hand
Walbro GSS341 fuel pump $50
FIC 650cc injectors $175
FP 4” intake pipe w/ couplings $100.00 looks like it had fittings on bottom that have been epoxied over.
Forge BOV - 1G flanged $125.00
2g dual dash gauge pod $20.00
3" turboback exhaust. Fits 2G AWD DSM. Bosal SS catback, mild steel downpipe $300
Competition Clutch 1620 (stg 4 w/ sprung 6puck disk) $250
aluminum radiator catch can w/ sight tube and pressure cap $40
Aluminum radiator - Godspeed brand - 2g direct fit $200
Momo steering wheel with mitsubishi adapter $175
link
Innovate LC1 wideband - control box only - no sensor $75
citymunky
Chesapeake, VA
Any word on Invoice ID: 7631329837996 (ordered on Feb 21/ 2012 at 7:27 PM)
-Trunk "door" cover for jack GVR4 Item # 213
-pillar plastic - Right - GVR4 Item # 191
NateCrisman
Blairstown, NJ
Quoting citymunky:
Will check on it...I distinctly remember picking the parts and packing/shipping that a few weeks ago...maybe like beginning of march! likely USPS lost. I'll see if I have a second set of those parts and will re-ship. Will email you asap once I know whats up.
Sorry!
belize1334
Bozeman, MT
Interested in your turbo outlet pipe. Do you have a pic of it mounted? Also, is the flange offset to match the outlet of a 16g/14b? I'm trying to get a "port-matched" fit without actually porting the turbo outlet.
Tre3zy
South San Francisco, CA
is the aem wide band still available????
NateCrisman
Blairstown, NJ
AEM wideband and the innovate sideband is still available. I actually have two innovate LC1's...one with sensor($100) and one without ($75)
NateCrisman
Blairstown, NJ
Quoting belize1334:
That turbo outlet pipe I want to keep with the intercooler so it's a bolt on matched up set. /ubbthreads/images/graemlins/wink.gif
Gordian79
Bronx,NY
Im interested in block and caps.Whats the block bored out to?
NateCrisman
Blairstown, NJ
Block is bored .020" over and the piston set matches. It's barely worn in, it has like 720 miles on the block/pistons/rods/caps/arps. When I pulled it from a parts car, the thrust bearing was starting to get chewed up and the crank had a few scores I could feel with fingernail. Im assuming the shop that built it didn't correctly set the oil clearances on the main bearings with those Jay Racing billet main caps.
NateCrisman
Blairstown, NJ
Quoting Gordian79:
sounds like they didnt line bore with the billet caps.
Very possible, I generally don't get into any situations where I would even think of needing custom main caps or line honing the mains. Basically this short block kit needs a set of new bearings, another stock crankshaft, and a competent machine shop to assemble it correctly and make the adjustments for correct clearances.
NateCrisman
Blairstown, NJ
Quoting Chase:
How many miles on that 2900 clutch? Any slipping?
not that I know of (slipping)....it should work fine. Came out of a FWD "dragstrip only" car I bought to part out well over a year ago. I doubt it has very much mileage at all.
1836d
Active member
NY
Nate I send you two email and no answer. Are you there yet? need the rotors
NateCrisman
Blairstown, NJ
I guess I need to check the spAm filter AgAin
NateCrisman
Blairstown, NJ
Quoting citymunky:
Finally shipped. I had to hack-em-up and make a box long enough, but it's done and gone for a second attempt. Extremely sorry for the long long long wait.
NateCrisman
Blairstown, NJ
Bump to the top, I'd like to move a lot of this stuff. reasonable offers accepted!
NateCrisman
Blairstown, NJ
bump...like to get rid of this stuff. List is up to date.
