FS: Random goodies
VR4Scott
Orlando, FL, USA
I cleaned up the shop a bit and gathered some things to post for sale:
Brand new OEM 2g non abs proportion valve - $40
Green top CAS - $30
Black top CAS (Made in 2009) - $80
Stock 2g Infinity amp - $20
95 Eprom TCU - $50
2g 609 MAF - $30
Crushed 1g BOV - $30
Stock 7 bolt FWD flywheel - $20
2GB blacked out headlights - $50
GVR4 thermostat housing - $20
Energy Suspension 2g front upper control arm bushings - $15
Good 2g window regulators with motor - $20 each
Rare early 95 2g eclipse (evo 3) rear big brake setup; rotors, calipers, hardware, brake hoses - $100
2g AWD rear hub assemblies, need new studs - $40 each
1g to 2g MAF harness adapter - $20
(3) 7 bolt/evo 162mm super long rod Manley Turbo Tuff rods mounted with 9:1 87mm Wiseco 1400HD pistons - $400
Get another rod, piston, and ring set and you'll have 2.1 destroker internals for less than a grand.
Prices are plus shipping or make a shipped offer.
turbojew
Dallas, Tx
pics of the evo3 rear breaks set up? Super interested.
VR4Scott
Orlando, FL, USA
PM me your email addresses or phone numbers for pictures.
birdman24
Cleveland, Ohio
Also interested in COP plate pics.
Terence
460GVR4
tacoma, wa
thermostat housing as in entire water outlet with sensors that bolts to cylinder head?
VR4Scott
Orlando, FL, USA
Yes entire thermostat housing with sensors.
I took the cop plates off because I found out they don't fit correctly. The bolt holes are slightly off and they don't sit flush in the valve cover because they are slightly too big. I wouldn't feel right selling them even for 10 bucks, unless you're ok with having to mod it to fit.
VR4Scott
Orlando, FL, USA
Bump
VR4Scott
Orlando, FL, USA
Updated
