FS: intercooler, sway bar, ac tensioner, intake, ngk wires, 1g bov, etc
turbophein
mass
Everything is plus shipping and 3% paypal fees unless you send as gift.
Dome light for sunroof car $40
NGK wires $30
10 inch and 12 inch slim radiator fans $40
Working AC belt tensioner $35
RC 750cc injectors, just had them cleaned and tested at FIC less than 300 miles since, new o-rings and seals. $150
Roja Light weight Wheels $400 they weigh a couple ounces less than my stockers with pirreli tires (local)
Intake pipe with K&N used with speed density on 16g style turbo. $40
AGX suspension stock springs $175
GR2 Suspension stock springs $125
Fuel sending unit and walbro 255 $200
ARP's used $50 might even have a packet of the lube
Poly Motor Mounts installed $800 Red
2G Throttle Body Elbow, with Air temp Sensor installed for Speed Density $25
Rebuilt Throttle Body maybe 500 miles on it, with all sensors $100
My FMIC setup, $200 or $275 with Real HKS BOV with the Important Recirculating Tube Adapter and Bov flange. it hangs a little crooked and is pieced together with a few different pipes but it works with the fog lights which is what i wanted most. sold
front sway bar $65
boost gauge $25 ultralite
Dejon Tool boost controller $25
turbo timer with HKS harness $35 worked great
Stock green 91 wheels with good hancook tires 85% $175
Stock white 92 wheels with snow tires 85% $150
