Tre3zy
(correct me if im rite...Wyldcarz been rolling hard for a long time)
12/11/10 06:55 PM
rear camber kit
just wondering what rear camber kit you guys are using.... thnx
-triz
turbofonz
(Member +)
12/11/10 09:36 PM
Re: rear camber kit
Ingalls in the Talon, Whiteline in the VR-4. I do my own alignments and both do the job well.
**DONOTDELETE**
(Unregistered)
12/12/10 02:45 AM
Re: rear camber kit
I picked up:
RAYBESTOS Part # 6111101
RAYBESTOS Part # 6111102
From rockauto.com They look alright, should do the job just fine. Make sure you order a set of MEVOTECH Part # MK9617 with them.
Adorsey
(Member +)
12/12/10 10:12 AM
Re: rear camber kit
I purchased these. for the Galant.
Shipped fast, and they work just fine.
Not the greatest of pictures, and not even fully put together. But you get the idea.
Tre3zy
12/12/10 10:47 PM
Re: rear camber kit
^ i think ima get this ones.... hey it says in the site that you need to grease the tie rod ends?
Adorsey
(Member +)
12/12/10 10:49 PM
Re: rear camber kit
They have a grease fitting on them.
Tre3zy
12/13/10 01:17 AM
Re: rear camber kit
ok you lost me LOL
Adorsey
(Member +)
12/13/10 07:22 AM
Re: rear camber kit
The fitting, circled in red. Is a grease fitting. It allows grease to be pumped throught the fitting, and into the balljoint.
Super simple to do, just friend a friend with a gtrease gun and have him/her do it. Or bring it to a shop or something and just ask them to do it.
Tre3zy
12/13/10 11:09 AM
Re: rear camber kit
ohhhh ok thnx bro.... just ordered it....
Adorsey
(Member +)
12/13/10 11:31 AM
Re: rear camber kit
Noo problem guy, happy ta help.
They are really nice fitting too, I hope you have good luck with them
KiNgMaRtY
(Member +++)
12/14/10 03:12 PM
Re: rear camber kit
Are we talking about front or rear? Tie rod connects to the AWS inner in the rear?
SouthCaliVR4
(Gas Analyzer)
12/14/10 04:29 PM
Re: rear camber kit
Rear, there is also a tie rod end on the upper control arm
Ralli380Gvr4
(Bearded Snow Leopard)
12/15/10 07:58 AM
Re: rear camber kit
Quoting Adorsey:
These seem to be good budget option to Tunesnation.com control arms I've been drooling over. cool
The price is very attractive, $155 compared to $355. They look a little less beefy but, for a street car and plan on a little track time, they seem like they would do the trick.
Tunersnation control arms.
Click
Adorsey
(Member +)
12/15/10 09:13 AM
Re: rear camber kit
I was tossed the package of the control arms when it arrived to my house. I caught it and almost fellover.
They were alot more beefy than I expected myself.
Anyone with access to a machine shop could easily turn out the chromoly shafts, and thread the inside for the other nessesary parts.
Everything else you could probably find at NAPA or online, and put these together for cheap. just a little note to any entrepreneurs out there.
KiNgMaRtY
(Member +++)
12/15/10 09:53 AM
Re: rear camber kit
Wow, then good price! Ever try finding just a tie rod for the rear? Good luck. I tried finding one for the AWS arm and could not find one. So you have a total of 4 outter tie rods in the end!
Looks like the $155 don't come with all bushings though. I may be wrong though
Adorsey
(Member +)
12/15/10 10:54 AM
Re: rear camber kit
I dropped my AWS rear subframe, and had one already built-up to put in its place. The one in the picture.
Went from:
AWS, ABS, 3bolt rear end, stock sway bar. bull
To:
4bolt, RM swaybar, new oem endlinks, poly mounts, *Chromoly upper adjustable control arms, clean looking rear end.
Only two outter tie rods
Generated in 0.006 seconds in which 0.001 seconds were spent on a total of 4 queries. Turbo powered.
