yeti
(Nope still sticky fingers)
11/21/20 09:50 PM
Clutch swap, locked out of gears. Broken fork? How do I check?
So I just got my transmission back and I played with the gear shifters and the input shafts and everything moved before I installed it,
I just tried starting it up right quick after installing everything but before torquing( transmission and transfercase torqued)
Started up fine but I was locked in neutral and my gear selector sticks to the left when in the 1st or 2nd area.
Pretty upset, kinda feeing like I just suck lol.
Could the miss shift from 3-2 at around 80mph of caused this? I limped home afterwards shifting terribly but still putting it in gears
God help me
yeti
11/21/20 10:54 PM
Re: Clutch swap, locked out of gears. Broken fork? How do I check?
I had the forking shifter cables backwards...
Sorry, I did this swap after a overnight work shift and still havenít slept.
Everything is gravy now, Phew.
KiNgMaRtY
(Member +++)
11/23/20 03:57 PM
Great to hear you got it worked out!
gvr4ever
(Forever Member)
11/23/20 06:47 PM
I'm surprised they fit backwards. If you were that tired, make sure you didn't miss that 1 back transmission bolt, that gets missed.
yeti
11/28/20 03:49 AM
Talkin about the little one that goes in the backside through the dowel? Was the first thing to get loctite
Generated in 0.004 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
