**DONOTDELETE**
(Unregistered)
01/31/12 03:50 PM
havin some rear camber problems
i noticed today my ds rear tire had more camber than normal like 45* unnormal. i do need the link but havent got the money yet. the problem is that the camber wasnt all till now. so i just went out like 5 min ago pulled the tire off and made sure nothing was loose. let car back down and now tire is streighter then ever. so i pulled car down driveway and back like 3 feet and its messed up again. whats going on
SouthCaliVR4
(Gas Analyzer)
01/31/12 04:11 PM
Re: havin some rear camber problems
Something broke You need to look again.
presterone
('92 Protege VR-4)
02/01/12 07:17 AM
Try loosening or tightening the eccentric adjuster could be just spinning around
**DONOTDELETE**
(Unregistered)
02/02/12 12:08 PM
i tried doing an alighment today and this is the best i caould get it
before
after
when i got home i checked the rear camber and there both fucked up again and way off
AnotherNewb
(flutterdumper)
02/02/12 12:49 PM
Quoting SouthCaliVR4:
This.
Check bushings, subframe bolts, strut tops, all hardware. Wheelbearings, tierod ends, control arms. If your camber is moving that much with just a little drive something is worn out or damaged. You jacked it up and didn't feel anything loose? You missed something. Checked it again before the alignment, missed it again. I would suspect something as drastic as the sub frame moving around.
**DONOTDELETE**
(Unregistered)
02/02/12 03:27 PM
Anybody have pics of where the talon rear end bolts on. I am giing to start there i have a good feelong thats my problem because i niticed one of the poly bushing was loose to the sub frame but didnt have time to look into it.
raptorWagon
(less than one year to my birthday)
02/02/12 03:58 PM
Check your lower control arms, make sure the ball joints aren't loose or the arms themselves aren't loose. The lower control arms control your camber, check to make sure the adjuster bolt, where the lower arm bolts to the subframe is tight and not loose. If those aren't torqued down they will rotate themselves from vibration. Make sure the Ball Joint holes on the arms aren't elongated either (you'll find out quick if your ball joint falls out)
Also check your trailing arm shock mounts for anything like this...This is bad, very, very bad.
SouthCaliVR4
(Gas Analyzer)
02/02/12 04:04 PM
actually the upper arm is the camber adjustment & trailing arm adjusts for toe. Now if it's as messed up as the pic you posted the trailing arm could cause a camber issue.
