LIV4PSI
(dyslexic 1051 )
05/18/12 04:43 PM
I cant upload pics
When I go to upload pics, I can't. I am sure that I have to delete part of the code, but I can't figure it out. For example
The image code shows when I go to edit, but not on the post itself? I'll copy and paste it
steveGalant VR4.org Administrator
(Key Fob Guy)
05/19/12 03:37 AM
Re: I cant upload pics
Yep looks like its broken.
HertzGalant VR4.org Administrator
(OneTitle to rule them all.)
05/19/12 03:40 AM
Sorry I had to delete the bestiality pics. Not appropriate.
dammitjim
(Member +)
05/19/12 11:12 AM
wat
LIV4PSI
(dyslexic 1051 )
05/19/12 11:46 AM
You guys, too funny. So even when I copy and paste the link, nothing shows up. I was hoping a mod could edit my post,look at the code the website was using, and let me know what happened. I can use photobucket, but I thought it was preferred we uploaded our pics to this server, right Hertz?
dammitjim
(Member +)
05/19/12 03:02 PM
LIV4PSI
(dyslexic 1051 )
05/19/12 03:39 PM
Now if you can just let me know why Im an idiot and cant do it, that would be must appreciate.
dammitjim
(Member +)
05/19/12 05:36 PM
Because racecar
Rausch
(Rock Star Status)
05/20/12 06:24 PM
LIV4PSI
(dyslexic 1051 )
05/20/12 07:27 PM
Thanks for all the help guys
dammitjim
(Member +)
05/20/12 07:41 PM
I just took the URL of your pic and used the "Image" link off the new post page.
holeshotmoe
(subclass marmoreus)
05/22/12 02:54 PM
Assuming you're trying to upload a picture from your PC. If so:
Whether a reply or new post, click in the Message block where you want the picture to appear. Make sure there's at least one space separating whatever you've already typed and the place you're putting your picure. Then click the "Upload Image into Post" button
Make sure your filesize is less than 2mb, not a .bmp image, and preferably .jpg format. Click Browse
Here you can see the file is .jpg and is only 15K. Click your file once to highlight it, then click "Open"
Takes you back to this window where you just click "Upload"
Now you will see the "code" needed to display your photo. Everything between the arrows, including brackets is needed. Add additional text either before or after this stuff then click "Add Reply"
Be aware that you'll only get this kind of instruction on this site!
LIV4PSI
(dyslexic 1051 )
05/23/12 03:27 AM
I appreciate you spoon feeding me, but that is exactly what I have been doing. It shows the code on my post, but the pics aren't showing up. This isn't my first forum, or my first time posting pics.
Edit: Actually, I think my pics are too big and that is the problem.
holeshotmoe
05/23/12 04:17 PM
Never know someone's experience so I figured I'd just lay it out there. In retrospect I could have checked your post count for a clue :-O
LIV4PSI
(dyslexic 1051 )
05/24/12 02:39 AM
I hope I didn't come off like I didn't appreciate your help, as I absolutely did. And I do agree that this is a different type of community. I am a Subaru owner as well and have been on Nasioc for the last few years, its cut throat over there.
holeshotmoe
05/24/12 03:36 PM
Not at all. Thanks.
