bobdole
(Old member with new to me VR4 and starting over. Respect your elders kids)
09/30/20 07:37 AM
Timing belt time
Will be doing my timing belt on 504/2000.
Just want to confirm part numbers and what I need.
I also seen the OEM water pump is the same as Aisin WPM-012. Is this correct ?
Thanks in advance.
boostme
(Junior Member)
09/30/20 11:37 AM
Re: Timing belt time
Yes, I believe Aisin is the OEM brand to Mitsu. I'll be using a Gates belts/water pump setup BUT with a OEM tensioner.
If it was a stock motor I would use the Gates Tensioner. But I have a couple pretty pennies in my motor so OEM it is.
bobdole
10/02/20 05:22 AM
Cheers Boostme.
GotInsulin
(Member)
10/05/20 09:19 AM
Yep, the Aisin pump is the same as Mitsu just with no Mitsu part number. I've used a handful of them over the years with great results. $50 trumps $150 every time.
Generated in 0.007 seconds in which 0.006 seconds were spent on a total of 4 queries. Turbo powered.
