mountaineerjeff
(<3 NJ)
11/22/11 09:14 PM
181/1000 the half-a$$ rally car
well I picked up number 181 as an alternative to running my jeep everywhere. I figured the gas savings alone would be beneficial. well like 4 days later it jumped time. well thats when the money pit started. once the head was pulled the valves were all smashed, and the pistons were nicked up. so the motor got pulled and I picked a 1g donor. the donor motor got stripped down, and completely rebuilt.
all new gaskets, BSE kit, new composite hg, arps, new valve cover, cyclone intake with a phenolic spacer, ported 2g exhaust manifold.
well when we went as pulled the motor, I decided to pull it all together. when the axles needed to come out I couldnt get them out of the knuckles without pulling the ball-joint. then I decided to replace the control arms since there was rust on the arms, and new arms come with ball joints. well when the old arms came out, the mounts were all rusted so thats when I decided that 181 would become a little more hardcore. no point in keeping a vr4 nice that has been rust repaired. so once I decided it would be a half-a$$ rally car we deleted the AC, cruise, PS, and ABS. the entire front sub-frame got replaced with new, new control arms, new brakes and suspension, prothane motor mounts.
then I went ahead and replaced the trans with a shorter throw 90' trans, act flywheel, new stage something PP and full face clutch, SS clutch line, with new cylinder, and new oem axles, and tcase.
with everything else the front went 5lug. with new bearings and the steering rack switched out.
after I got it.
begin the tear down.
begin of rust repair, and can see the partial damage.
mountaineerjeff
(<3 NJ)
11/22/11 09:20 PM
Re: 181/1000 the half-a$$ rally car
reassembled motor
motor/trans/tcase all installed.
(295hp 35r BR4)
11/22/11 09:23 PM
I like how you matched the intake manifold with the valve cover. Never seen that before, very nice.
mountaineerjeff
(<3 NJ)
11/22/11 09:25 PM
oil pan
kyb/agx/eibach new mounts. they got cleaned then painted black
mountaineerjeff
(<3 NJ)
11/22/11 09:33 PM
Quoting GSX_TC:
thanks alot, I like to keep the flow.
heres the first move. we zipped it up together real quick to move it across town to the garage with the lift.
with and without my garage partner. you can see my new CF hood, and how its still 4-lug in the rear.
mountaineerjeff
(<3 NJ)
11/22/11 09:38 PM
rear sub-frame dropped out.
new rear everything, with gsx stuff to delete the 4ws completely. along with the 5-lug, rear kyb/eibach
here it is under its own weight. with rear strut bar. blacked out markers, and antenna delete
mountaineerjeff
(<3 NJ)
11/22/11 09:44 PM
front view. I think that it should be dropped some. it was already dropped one inch, but it looks higher than stock with all the weight I have pulled out.
there are a lot more mods under the hood, but I havent been too worried with pictures. I have a mishimoto rad, a braille battery, hood latch delete, all non-abs lines with galant abd proportioning valve.
(295hp 35r BR4)
11/22/11 09:54 PM
Sweet, I see a 90 External oil cooler
mountaineerjeff
(<3 NJ)
11/22/11 10:10 PM
yea, there are hundreds of little mods like that. external oil cooler, huge FMIC, blacked corners, and turn signals. everything unnecessary removed and deleted. just waterpump,oilpump, and alternator are teh only things left.
it also has the jmf heat shield ceramic coated, along with the o2 and intake and exhaust mani being coated as well. for temporary I have a 2g,560s and a keydiver. but I need to get a new chip for the cyclone, my evo8 mafs, and bigger injectors. I have a an in cabin mbc, aem uego, and boost gauge, along with a palm for data logging.
things that are getting done before the weekend, is the wiring harness being stripped, radio delete, ac core delete, and probably have the interior slimmed down. hopefully getting my piping done, and the front end reassembled.
(Old Balls)
11/22/11 10:21 PM
I was told that the 1990 trans were weaker internally. Can't recall but I think it has to do with less renforcement webbing or something or the other.
Has anybody else heard that?
mountaineerjeff
(<3 NJ)
11/22/11 10:29 PM
its a moot point as far as my build is concerned. it provides a smooth short shift, without changing my shifter height. as far as power, Im positive it will hold a 16g just fine, especially during the winter, when my weakest link is traction. by the time the trans could be an issue, it will get a built trans that will handle bigger numbers. right now its in winter beater mode.
jepherz
(Too Clean)
11/23/11 02:53 AM
Quoting Terry Posten:
I thought the only real difference was crappy synchros.
mountaineerjeff
(<3 NJ)
11/30/11 12:10 AM
well I have gotten some more work done, but its all been done late at night, so the pics are too dark, but I moved the fuse box to the firewall, along with mounting my braille to the firewall as well. made some new wire ends and grounds. and started on the intercooler and piping. the wiring was moved on the inside of the 'frame' rails, the the headlight supports were 'modified' and the radiator mounts moved to allow the intercooler piping to run on each side of the rad.
most of the sound deadening has been pulled from the trunk, and the seats have been pulled, and are going in #1630. Ill try and get some of the crappy pics loaded.
and a little bit of a teaser, its not quite done yet, and the pics are super dark, but you get the idea
mountaineerjeff
(<3 NJ)
12/01/11 05:15 AM
well I got some major progress for once. got the rear seats in and bolted down. not as picky as some on here, but they are secure and comfy. front still WIP.
mountaineerjeff
(<3 NJ)
12/01/11 04:38 PM
I also got the end tank on the intercooler welded up, Ill get some pics of the work today, but all I have now is it test fitted on the car.
the 'sweet' "3VOM" is coming off, though. its not in my taste, but luckily it cant be seen with the bumper on. it will eventually get anodized.
mountaineerjeff
(<3 NJ)
12/01/11 04:40 PM
all buttoned up.
DR1665
(Kill him in the face with Wilson Phillips)
12/01/11 07:46 PM
All buttoned up.
Quoting GSX_TC:
For maximum effect, also paint the exhaust heat shields to match. (Welcome to 2007, a few months prior to The Kia Incident.)
mountaineerjeff
(<3 NJ)
12/02/11 04:25 AM
for a bit of a side by side comparison brian. JIC you missed the fact that the exhaust is already black.
mine. before I finished the bit of a wire mess on the firewall.
mountaineerjeff
(<3 NJ)
12/02/11 04:31 AM
getting a little bit closer to being a full fledged RallyFart
I think its centered pretty well.
If they seem a little crooked, this was during the first 'test' fit. AKA just tossing them in.
DR1665
12/02/11 03:04 PM
Quoting mountaineerjeff:
I am a retard.
mountaineerjeff
(<3 NJ)
12/02/11 03:44 PM
no prob. I still have to wait on the pipes to be done so I can coat them s well. Im also thinkin about a spark plug cover, but IDK.
mountaineerjeff
(<3 NJ)
12/06/11 08:05 AM
well the ricers here are out of control, so I decides that stuff needed to get a little more serious and chose to go ahead and gut the interior. I pulled the seats again. then started beating all the sound deadening out
mountaineerjeff
(<3 NJ)
12/06/11 08:13 AM
some rust repair, then primer.
seat bracket
mountaineerjeff
(<3 NJ)
12/06/11 11:26 AM
passenger side cleanup
seats are in for good.
we pretty much got the interior finished for now.I still have some more advanced plans for it down the line, but being broke doesnt help. just need to make a gauge pod and ill be good.
ScreaminE
(Just don't like an idiot)
12/06/11 01:22 PM
I never would have thought Morgantown would have ricers.
mountaineerjeff
(<3 NJ)
12/06/11 04:48 PM
yea they are pretty bad. the guys around here that actually know what they are doing, always go out of town so all the ricers live in this small world where they actually think their garbage is fast.
mountaineerjeff
(<3 NJ)
12/07/11 04:26 AM
really hard to get some goo interior shots, but the interior is pretty much done. all weight removed. seats and brackets all done, everything repainted. speakers removed. All I have to do now is mount my gauges. I took out MASSIVE amounts of weight from this car.
the trunk is gutted as well. this is just the first coat after the primer, so it obviously gets better.
we also got the intercooler finished and mounted. also have the oil cooler cleaned and mounted. and the bumper is partially done. more pics tomorrow.
mountaineerjeff
(<3 NJ)
12/08/11 06:50 AM
Intercooler is all done. its mounted. tried to show how it was modified from the 1g setup.
mountaineerjeff
(<3 NJ)
12/08/11 06:58 AM
I also got the front bumper finished. i think it turned out petty well.
I also got the CAD done on my radio bezel.
mountaineerjeff
(<3 NJ)
12/09/11 10:50 AM
i got the front end all tidied up. the bumper is mounted, and the blinkers have been put in, and wired back up. I still have to get the foglights mounted, which fit perfectly even with the large inter-cooler. the grill is also mounted, along with my blacked out tri-diamond.
mountaineerjeff
(<3 NJ)
12/09/11 05:52 PM
headed back to the shop, let me know if there are any parts of the build you want better pics of, and ill try and get em in better light.
mountaineerjeff
(<3 NJ)
12/16/11 10:53 AM
pretty much got her back to running condition. I need some more light under the hood to get some good pics. the only thing left is my exhaust. on top of just running, I still need to mount my gauges, and switch in my injectors. then I need to find a way to run some bigger 1000+ injectors.
mountaineerjeff
(<3 NJ)
01/03/12 02:09 AM
well we went pretty much idle there for a couple weeks, partly due to the holidays, partly due to me giving my jeep some attention, and mostly due to the fact that I lost the stinking keys for it! I got a brand new one made at the dealer for $10. it is SOOOO much nicer then my last one. it doesnt snag or catch, and is of very good quality.
After having the engine bay all back apart, rerouting the harness, doing the intercooler piping, and converting a lot of little things, 181 still started right up. I just hooked up the battery, stuck the key in, and turned it right over. started first try.
she is still sitting at the shop as there are a few things I need to be streetable. Need to get an intake the doesnt interfere with new piping layout, bleed the brakes and clutch, and get the exhaust together, and shell be good to go.
Got to get it up and ready so I can make some sweet snow vids.
mountaineerjeff
(<3 NJ)
03/07/13 08:04 AM
so it literally sat for a year....after starting it up, and driving it around a little bit it had a steering issue, so it sat for a while before I could look at it...a helper put the wrong bolt back in the collar on the steering column. fixed that and then it refused to start. well it had fuel, spark, compression but would not run. do to me starting to race the jeep it just got put on the back burner...well I finally got a space cleaned out in the garage, got it moved from where it was in storage, pulled in the garage, and running within 15 minutes. I think it actually sat for a year, purely because of a bad battery. I tightened up some grounds, check the pump, put a "shop battery" in it and she sputtered to life. fixed the vacuum leaks (just hoses that were pulled during diagnosis) and she runs solid again.
took a startup vid, will get some new pics put up later. The project is finally up and going again. while its in the garage I have got to finish the intake and exhaust, and finish the headlight wiring harness, from my partial tuck/me deleting everything. throw on a slim fan and she will be daily-able. then after that I have to finish my evo ecu harness, get my gauges and such working to make it safe to turn the boost up. then its time for pump. then afpr, prolly some HUGE injectors, and then the biggest bolt on turbo I can find.Most likely just a 'sleeper' 20g. I need to keep my piping, and the stock appearance.
Ill also be starting stage 2 of weight loss, and rust repair. with all that said and done (honestly IMO isnt very much) Ill need to find a CF trunk so I can get the car painted before the shootout. I should also have the N2O hooked up before then as well. my only other plan after that will be to put together a spare/second motor with evo internals. Which will only be if I find the limit of 6bolt rods vs a td05+n2o, but that is just for the hopeful future...It would be nice to have the car 1005 complete before the shootout...which as long as I can find the $$$ and a trunk I should be golden.
more pics to come. (cant find usb cord)
(295hp 35r BR4)
03/07/13 09:23 AM
It's coming along nicely =)
DynastyLCD
(Dissapointing Member)
03/07/13 09:46 AM
Evo rods are 7 bolt which wouldn't be compatible, not to mention they are weaker than 1g rods. what would you plan on using for your Evo internal build?
i think you'll find the limits of the piston ring lands before you find the limits of the rods
rexwagon1909
(impatient cutter)
03/07/13 11:31 AM
Hey man build looks good so far reminds me of my Glaant GSX build, I think mine was a rally car as well lol. Good to see another VR4 in WV. GLW the build
mountaineerjeff
(<3 NJ)
03/07/13 11:40 AM
well Im not positive what route im going yet, but Im thinking of running a 99 block, with a full evo 9 rotating assembly, along with cams, and valves. around here we do "road rally" and point-point racing. so the gain from compression and lightweight internals will be much more useful than a slightly stronger rod. the plan is to max out a TDO5 then have a N2O system to push it to the limit of the internals, whenever I need that little extra oomph. like when I run into the unsuspecting gtr, or the like.
I think that is far inside the capabilities of the evo rod, while still giving me a lighter faster revving setup that will be happier when I get closer to 8k rpm. plus I like using OEM components. they seem to have the longest life, plus I can get the parts super cheap. since I do all my own work, Id rather push 500hp out of a 450hp system that cost $100 to replace, than to push 600 hp out of a $5000 motor. one major thing to remember is Im limited to the td05 housing, and this is NOT a drag car, so peak power isnt the goal.
Ive also considered doing a 2.4L as well, but dont know if the TQ will be better, or the revs and RPM of a lighter 2.0l
mountaineerjeff
(<3 NJ)
03/07/13 11:50 AM
Quoting rexwagon1909:
get a hold of me if ya ever head up this way, Ill even sign ya up to join us in a cruise, or maybe you can join our convoy to the shootout.
rexwagon1909
(impatient cutter)
03/07/13 11:56 AM
Sweet sounds good man! Fingers Crossed on going to the shootout this year, engine is just about to be built then trans installed etc. And I need to get a truck to tow it lol.
mountaineerjeff
(<3 NJ)
03/07/13 12:03 PM
AAA FTW...my buddy has a 350 superduty and we talked about just bringing it with a car hauler and charging people to return their broken rides home, lol.
well let me know if I can help, or if ya need anything
mountaineerjeff
(<3 NJ)
03/09/13 07:52 AM
still havent found my cord yet, but I got a decent amount done today.go alot of the engine bay cleaned up and sorted out, finshed extending and tucking the headlight harness, then putting in all new bulbs.
seems like there may be some idle/air/vacuum/leak issues, but I havent gotten to take it for a spin yet, so some of it might just be the nature of the beast
mountaineerjeff
(<3 NJ)
03/10/13 04:29 AM
started refreshing my carbon hood. got to wait until monday to get supplies, but ill get it done, then as soon as I find a CF trunk Ill be repainting the roof. there was clear coat peel on the roof/hood/trunk. so after the cf hood and trunk ill just color match the roof and I should be good to go. I would LOVE to do a carbon roof, but in reality its not going to happen to 181. (1630 might get something special though) It would be nice to get a carbon sunroof replacement though.
tomorrow I plan on fixing some more rust, and possibly making an intake pipe. it will most likely be temporary but i need to get my BOV recirc. I might go ahead and do a temp fix on the clear coat as well. but after thats done Ill be back at work finishing up my evo8 ecu adapter. need to remember where my evo MAF wiring has hidden itself.
mountaineerjeff
(<3 NJ)
06/18/13 01:22 AM
finally got a second to give her a little attention. timing was way off, cam sensor was out, couple good boost/vac leaks, and wastgate was sticking.
knocked those little things out, and she is running like a beast again. still not fast, as I have to do a tune after I up my fuel system, but def way faster than stock. partly due to upgrades, and part due to the weight ive stripped.
right now, I need an intake, and an exhaust, and she will be street-able again.
(295hp 35r BR4)
06/18/13 10:25 AM
Nice, you bringing this to the Shootout in august?
mountaineerjeff
(<3 NJ)
01/15/14 09:33 PM
Well, she is officially back on the priorities list. Been sitting for way too long. Getting parts gathered to get it back on the road. The biggest thing that was holding me up, was the fact that I don't have an exhaust. Well I believe I have found a solution to that, so this thread should be getting a ton of updates from now on.
mountaineerjeff
(<3 NJ)
01/21/14 12:10 PM
Got my front subframe in. cant wait to get this back on the road.
EHmotorsports
(Capt Fabbin Stabbin)
01/21/14 12:17 PM
good to see her getting some love again:)
mountaineerjeff
(<3 NJ)
01/21/14 06:48 PM
Yea, I've had a lot of set backs, but I kept it in the garage, and held out until now, I got a decent job and enough income that I can afford to get all the little loose ends caught up.
mountaineerjeff
(<3 NJ)
01/21/14 09:56 PM
Got a chance to take her for a little spin after chasing down a vac leak. Afterward I went ahead and threw the new subframe in. It's pretty awesome.about 10lbs lighter and way beefier. Should really help the handling. Got to take a look at my front caliper which seems to be sticking, but also waiting on my new wheels and lug nuts.
mountaineerjeff
(<3 NJ)
01/22/14 06:40 PM
Almost done with her temp attendance of team JSB. Just gonna take a look at a sticky caliper and take it out to see if the new subframe is noticeable. The main reasons were for space and weight so any handling will be a sweet bonus.
mountaineerjeff
(<3 NJ)
01/23/14 05:13 AM
Well I got my sticky caliper cleaned up, subframe all retorqued. The results are night and day. The car is fun to drive again.
mountaineerjeff
(<3 NJ)
01/25/14 04:08 PM
Started cleaning it up some, so it looks as good as it runs
mountaineerjeff
(<3 NJ)
01/25/14 05:23 PM
Needed to fix the faded trim and handles. Along with the clear coat on the roof.
coyotes
(Hipster VR4)
01/25/14 05:25 PM
what are your plans to fix the roof clear coat? I have some peeling clear coat on my car also... not sure how to fix.
mountaineerjeff
(<3 NJ)
01/25/14 05:26 PM
Time to clean up that sunburnt hood.
mountaineerjeff
(<3 NJ)
01/25/14 05:29 PM
Hood cleaned up, and the roof sprayed. Looks about as good as it runs now. It's no show car, but it's not a race car either.
mountaineerjeff
(<3 NJ)
01/25/14 05:32 PM
Quoting coyotes:
Sorry, was on a roll and missed you question. I just went the easy route and used Plastidip. If it was a better chasis I'd take the time to take it Down and repaint it. But for this car, and any daily driver on a budget, Plastidip works fine and looks a hundred times better
coyotes
(Hipster VR4)
01/25/14 06:24 PM
I would just do that too if it was my roof, but my clear coat is peeling on the passenger side rear panel, so plastidip wouldn't match it very well.
mountaineerjeff
(<3 NJ)
01/25/14 07:16 PM
2 tone it at the body line. Just run a tape line from the corner light back to the taillights and call it done. Or you could commit and do the whole car.
Took her out for a spin and wasn't getting heat. I was pretty sure I left the heater core intact, but it was possible the hoses were just looped. Well pulled into the garage and it was about half empty. I remembered having a slow leak around the t-stat, so I filled it up, and it instantly poured all over the ground. Found a blown rear freeze plug :-(.
Ran and got a new plug, and that fixed the leak. Waiting on the permetex on my Tatar to dry and I'll take her out again tonight.
mountaineerjeff
(<3 NJ)
01/25/14 09:37 PM
Out in it's natural habitat.
Generated in 0.006 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
