**DONOTDELETE**
(Unregistered)
11/15/11 05:03 PM
Trunk Cable not opening trunk
It just started one day. I can see that the red plastic bit that goes to the rear latch is broken, so I held it in place and had a helper pull. The cable still doesn't pull quite enough to open the trunk.
Seems like a simple but annoying problem.
Ideas?
Re: Trunk Cable not opening trunk
On mine the cable got stretched & needs to be replaced. check that it's still mounted to the clips on the hinge & the retention clips that run under the back seat.
so you dont know why its not working still?, sounds like a future junk yard trip to me.
**DONOTDELETE**
(Unregistered)
11/15/11 08:52 PM
Quoting SouthCaliVR4:
I guess I'll check all that stuff out...thanks.
**DONOTDELETE**
(Unregistered)
11/15/11 08:52 PM
Quoting omertaitalia:
No idea, no Galants of these years appear in junk yards here even the big ones.
On my car I know the lever is just weak and pulling bends the lever rather then pulling the cable.
(Space Blanket from NASA plumbed into the attic)
11/16/11 12:40 AM
Take the cable off in the back and crimp on a steel or aluminum cable clamp piece available at any hardware store or just put a zip tie on it to take up the slack. Fixed without having to tread the cable from under the carpet etc.
**DONOTDELETE**
(Unregistered)
11/16/11 01:52 PM
Thanks for the thoughts...tie wrap sounds good to me even if diagnostic.
(Hard Snarker)
11/16/11 03:04 PM
I think I tied a knot in mine to take up some extra slack. If I recall...it's been awhile.
**DONOTDELETE**
(Unregistered)
11/21/11 10:24 AM
Appreciated
**DONOTDELETE**
(Unregistered)
11/23/11 07:50 AM
Tie wrap worked ok FYI...
