**DONOTDELETE**
(Unregistered)
05/31/11 10:01 AM
aws light
Today as I was driving to work I noticed my aws light was on. I stopped and turned the car off, then back on and it shut off. The light would come back on any time I took a hard right turn. I'm new to the gvr4 and not really sure where to start with fixing this aws problem. I tried searching, but the search function on this forum never seems to give me much luck.
I've read up on a lot of ppl just taking out their aws, and honestly if that's the easier solution then I wouldn't mind just doing that. I hardly even notice the aws kick in anyways.
Thanks in advance,
-Brian
Struc
(Not all filled in)
05/31/11 11:15 AM
Re: aws light
Your fluid level is probably low.
SouthCaliVR4
(Gas Analyzer)
05/31/11 12:06 PM
Re: aws light
The light is attached to a level sensor in the fluid res. as stated your probably just low on fluid. be sure & check the system for leaks.
**DONOTDELETE**
(Unregistered)
05/31/11 12:33 PM
Re: aws light
Cool I'll check the fluid level at lunch. Thanks guys I totally should have thought to check that first.
Dasith
(I've never been to usa, but prostitution is probably legal there i think.)
06/01/11 05:08 AM
Re: aws light
hi
where is the fluid reservoir??
SouthCaliVR4
(Gas Analyzer)
06/01/11 12:04 PM
Re: aws light
^^ drivers front, next to the timing cover end motor mount.
Edit: passenger side for you
Dasith
06/02/11 12:32 AM
Re: aws light
thanx mate
**DONOTDELETE**
(Unregistered)
06/02/11 02:29 PM
Re: aws light
Problem solved
Generated in 0.01 seconds in which 0.008 seconds were spent on a total of 4 queries. Turbo powered.
