The_Big_Weave
(Member +)
05/07/10 01:26 AM
Wastegate issue
Can the diaphragm in a wastegate go bad? I have a wastegate I pressure tested and the air blew right out of it. what can I do to fix this?
pmp285
(Junior Member)
05/07/10 01:28 AM
Re: Wastegate issue
seals inside might have broken off. same thing happened to my friends evo5... he just bought a new WG
The_Big_Weave
(Member +)
05/07/10 01:33 AM
Re: Wastegate issue
Yeah Im having trouble finding one.
**DONOTDELETE**
(Unregistered)
05/07/10 02:14 AM
Re: Wastegate issue
Does the diaphram have holes or torn? If not replace the fittings and try again. Just got done dealing with what sounds like a similar issue. Aluminum fittings and gaskets that came with WG did not seal proper so I used 1/8 brass pripe with a nipple on it and held enough pressure to open.
talon
(forbidden fruit creates many jams)
05/07/10 08:26 AM
Re: Wastegate issue
Is your wastegate a cheap ebay brand or Tial? If its Tial or an ebay version of Tial, then you can buy replacement parts. click
You will have to email Tial for prices. I dont know where else you can buy parts for them at.
**DONOTDELETE**
(Unregistered)
05/07/10 09:37 AM
Re: Wastegate issue
The only thing I cheaped out with on my setup was the WG. Yes, it is an ebay knockoff. But I have yet to see one that didnt work. You can test it with a simple hand pump. I used my penis pump.
The_Big_Weave
(Member +)
05/07/10 05:37 PM
Re: Wastegate issue
I have a stock wastegate
91GVR4#479
(Senior Member)
05/07/10 06:03 PM
Re: Wastegate issue
Just to let you know, I'm a Urologist and I've prescribed and seen penile vacuum pumps used in what i thought were just about all the ways possible......but this is a new one for me.
**DONOTDELETE**
(Unregistered)
05/07/10 07:39 PM
Re: Wastegate issue
Do the best with the tools at hand right?
