(Old Balls)
10/08/07 03:27 PM
3G MAS limitations.
Does anybody know what the over-run is on the 3MAS?
Is there a air metered frequency that I need to stay below to keep this unit in 1 piece and not have the honeycomb get sucked in?
I am running a Keydiver chip that he custom programmed for a 2.3L using the 3G MAS and 750 injectors.
OldHairyBastard
(I take bottom on trannies)
10/08/07 04:40 PM
Re: 3G MAS limitations.
Is the motor completed and your ready to rock. Sorry for the thread jack. Just wanted to know.
**DONOTDELETE**
(Unregistered)
10/08/07 07:29 PM
I think Mark made 580 whp then the comb got sucked in on the Evo 8 mas. It was a used unit though. I'm pretty sure a new one will stand up to more hp. Not sure what the over-run point is as far as exact #s. Check dsmchips.com to see if Jeff has some detailed info there.
(Old Balls)
10/08/07 10:52 PM
I will MAYBE get 550-570 crank HP and my MAS was new from Icce.
I really don't want to mess around with a new intake setup.
The next spendy purchase will be a 4bolt and then a good exhaust mani/external WG/custom DP.
**DONOTDELETE**
(Unregistered)
10/09/07 06:32 AM
For those power levels you'll be good. I was planning on 600 whp with my evo 8 mas. It's been done before but you need all the right combinations. That was the reason I was going to stick with my intake setup as well, just didn't want to change it as it was functional & the money could be spent in other more needy areas.
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
