atsiauto
(Senior Member)
05/12/03 01:36 PM
boost leak at butterfly on TB
I have boost leakage, you can hear it seeping through the throttle body , anybody know the fix or do i have to go buy a whole TB ,. used Justins hommeade deal again to find the leak .
Dan D
(220, 221... whatever it takes)
05/12/03 01:47 PM
Re: boost leak at butterfly on TB
VFAQ
http://www.ca.dsm.org/faq/tb-shaftseals.html
http://www.plymouthlaser.com/tbor.htm
Search Function
http://www.galantvr4.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001154
HertzGalant VR4.org Administrator
(OneTitle to rule them all.)
05/12/03 02:11 PM
http://store.yahoo.com/machv/throtbodseal.html
autobahntom
(Senior Member)
05/12/03 02:53 PM
The CR seals are about $11 each, follow the VFAQ. Very nicely written.
Tom
Turbo4door1
(Paid to pewp)
05/12/03 03:24 PM
I just did this last week. I purchased the seals through Mach V. I believe they were $10.00. Very nice pieces. They replace the factory metal ring/rubber o-ring deal completely. Which is a good thing, because I completely buggered up one of the metal rings getting it out. I followed the faq, and didn't have any problems at all.
atsiauto
(Senior Member)
05/12/03 03:51 PM
did you replace any TB gaskets as well ?
Turbo4door1
(Paid to pewp)
05/12/03 04:21 PM
I had two of them, so I did replace the gaskets from the throttle body to I/C pipe, and the throttle body to intake manifold. You really could just use RTV in a pinch. Other than the two throttle shaft seals, that is all I replaced. I haven't pressure tested it since I put it back together, but it seems to be much better.
atsiauto
(Senior Member)
05/12/03 04:31 PM
thanks everybody , I just ordered 2 sets e nuff to do both cars , I didnt realize they were so close,
**DONOTDELETE**
(Unregistered)
05/13/03 11:26 PM
Do you think the $10 (plus shipping) MachV o-rings are worth it?
I have the #7 (1/2x3/8x1/16) o-rings at work (free).
Turbo4door1
(Paid to pewp)
05/13/03 01:39 PM
Joe --
Yeah, I think it was worth it. They completely replace the stock metal ring / O-ring combo. I think the outer edge of them are still metal, but they are completely enclosed with rubber and have grooves on the sides to help with sealing. I completely messed up one of the stock metal rings when trying to pry it out, so it was a good thing that they replaced it...!!! [Wink] As a side note, if you order online through them, it automatically will charge you 6.00 for shipping. They adjusted the shipping accordingly when I actually recieved them.
**DONOTDELETE**
(Unregistered)
05/14/03 04:03 AM
Yes they are worth it.
Generated in 0.005 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
