91vr4auto
(Newbie)
11/26/19 04:48 PM
Front Lower Control Arms
Hi, does anyone know if there are any differences between the FLCAs for LHD and RHD cars? Need to replace my balljoints, and looking at RockAuto's site it has complete FLCAs starting at $61 each, with new balljoints, and I guess, new bushings. Also, the site lists Mevotech arms for $61 and ACDelco for $144, any real difference between the two? Thanks, Mike.
(Turn Right Racing)
11/27/19 07:24 AM
Re: Front Lower Control Arms
There should be no difference for these vehicles RHD v. LHD.
I can't speak to the relative quality for the price difference. I will say that I put a Dorman part on my car a few years back (probably longer ago than I think...), and the ball joint boot basically has rotted away on it. Very disappointing, buy maybe I should not be surprised.
I will also add that I have not used a Mevotech control arm, but I have purchased their tie rod ends and sway bar links. They seem decent quality and their boots sometimes are made of a different appearing rubber, maybe silicone.
ercp98
(perpetual n00b)
11/27/19 01:30 PM
Hi, i have used the mevotech lower control arm from rock auto.
I can not remember if i had to order left or right specifically, but i replaced both. It has seen 6 years of chicago weather. I only noticed this past summer the passenger side lower control arm has a slight movement. The control arm bushing are on its way out not the tie rod. So i was able to get 6 years out of them. Hope that helps.
91vr4auto
(Newbie)
11/27/19 06:59 PM
Yes it does, thanks very much. Six years is probably more than you'd get out of poly bushings I would think.
(Senior Member)
11/27/19 11:02 PM
there is a post some where showing one of the replacements with very poor construction. I don't remember which, but its worth a search before you order junk we have been warned about.
christo
(Member)
12/02/19 08:15 AM
I used some Mevotech ball joints and tie rod ends before on my wifes old Honda Accord. I ended up having to replace one of the ball joints a year later due to the ball rusting out FWIW. I might have just got a bad one Ended up selling the car not too long after that so I am not sure how the others held up.
(Senior Member)
12/02/19 09:11 AM
I've gone through Mevotech ball joints and tierods in less than 2 years too on my Subaru. How much should you expect from 12-15$ parts though.
pagosadsm
(Junior Member)
12/06/19 09:39 AM
I used a Mevotech control arm. Modd it to fit a Chrysler upper ball joint. part # Speedway 910-34323
Installed a steel ball sleeve #106-20041
welded a 1/2 threaded block to attach the sway bar to the control arm
Machined a steel bushing for the rear bushing
You can see photos on Tunners
Rick
("Just to be pedantic!")
01/16/20 03:13 PM
Quoting 91vr4auto:
If you just need ball joints why would you not just replace them on their own? You can get decent joints from BnT, Auto1, Repco, Supercheap etc for much less than a complete LCA - and you don't have to wait for them to come in from overseas and be subject to GST etc. The joints will need to be pressed out and pressed back in, but any competent mechanic with a press can do that in 5 min.
And for the US guys, NZ cars don't tend to get chronic rust issues so the OEM LCA's are probably still perfectly fine. I would prefer keeping an older used OEM LCA in instead of a cheap new aftermarket unit - have seen too many of them manufactured so poorly and they just aren't built to last. Stay away from Dorman products.
Generated in 0.005 seconds in which 0.004 seconds were spent on a total of 4 queries. Turbo powered.
