gvr4ever
(Forever Member)
05/25/19 06:42 PM
Clutch pedal assembaly.
Are new parts still available?
Getting my car back up to par. Getting close, but the clutch grab is low. I think a ACT 2600 did the wear and tear. Currently running a centerforce. A lot lighter, but I still don't have enough play.
Drewpy_Dawg
(Newbie)
05/27/19 10:33 AM
Re: Clutch pedal assembaly.
The lever at the end of the clutch pedal assembly that wears out is no longer available, unless somebody on here has an unused one lying around. Other than that I think your only option is to have your lever welded. The good news is that it won't wear out again.
05/28/19 08:01 AM
If your gonna weld it you need to get the brass bushings from JNZ, the stock bushings will melt if you try to woed with them in place.
05/28/19 08:03 AM
Not sure if it's available, but rtm has them.
Generated in 0.009 seconds in which 0.008 seconds were spent on a total of 4 queries. Turbo powered.
