gotbl4d3
(Junior Member)
10/31/16 09:56 PM
keeping blowing ignition fuse trying to set idle
Hey guys I was wondering if anybody has had an issue blowing a fuse
Grounding the two points to isolate the isc to set idle. I did notice there is another wire by the fire wall that was broken off I am not sure if I am grounding the wrong there or the one under the dash on the obd connector if somebody could give me some input that would be great Thanks.
donniekak
(Member ++)
11/01/16 08:29 AM
Re: keeping blowing ignition fuse trying to set idle
You are grounding the fuel pump check connector.
gotbl4d3
(Junior Member)
11/01/16 12:27 PM
Okay so ground the other connector right next to it by the clutch master cylinder which pin do I ground on the obd plug?
