sixcentz
(Newbie)
11/17/15 01:45 AM
Smoke suddenly pouring out of exhaust & catch can breather - 1990 VR4
Hi guys so I have a 1990 vr4 which has started pouring smoke out of the exhaust & catch can breather, this has all happened suddenly - went from no smoke at all to now looking like a train.
The smoke is white out of the breather & exhaust while idle, though blue when I'm giving it gas while driving.
Engine has been fully rebuilt only around 3000miles ago (by a shop)
I have done a oil change about a week prior to this, I've used 15w40 though I don't see how this could be the cause, should also probably add that I did have a issue with oil squirting out of the dipstick though this seems to have stopped.
Is my first turbo vehicle so bare with me
Any help would be very much appreciated!
EHmotorsports
(Capt Fabbin Stabbin)
11/17/15 04:29 AM
Re: Smoke suddenly pouring out of exhaust & catch can breather - 1990 VR4
I would recommend doing a compression and leakdown test first. Also check to see if oil is in coolant. That will at least tell you if you have a blown head gasket.
(A hole)
11/17/15 07:17 AM
Could be the turbo seals have gone as well. Pull the intake pipe and check for a pool of oil.
("Just to be pedantic!")
11/19/15 08:19 PM
the oil is following a path of least resistance - if the dipstick has stopped popping out then the oil is finding another way out, and it seems it's probably through a turbo seal. I would find the source of why your crank case is being over pressurised - if it were me I would revert back to the stock PCV valve configuration.
