MellowVR4
(5" too short)
07/07/15 11:37 AM
Rear hub bearing question
So, about a month ago I replaced my driver side rear wheel bearings ( they were growling pretty bad ). While I was in their I removed the abs ring on the one side since, now when I take off I have a slight vibration on that one side... Would removing the abs ring cause a balance issue to happen?
Any help would be great, thanks.
89Mirageman
(It's no Mirage, man)
07/07/15 11:48 AM
Re: Rear hub bearing question
Doesn't that ring just slip on? Can't see that cause a vibration, I'd look elsewhere.
07/07/15 11:58 AM
Did you torque your wheel?
Abs ring removal won't cause that issue.
(Turn Right Racing)
07/07/15 12:00 PM
Did you reuse the correct shoulder bolts for the axle cups? Very important to use those in that type of load application.
MellowVR4
(5" too short)
07/07/15 01:04 PM
I reused the hardware for the cups, I did not torque my wheel tho.
MellowVR4
(5" too short)
07/07/15 01:18 PM
Unless my caliper is sticking, it really only happens when I get on it. fades away tho.
07/07/15 01:33 PM
Quoting MellowVR4:
Really? Start there, I bet your wheel isn't fully seated.
MellowVR4
(5" too short)
07/07/15 01:44 PM
I will do that and report back. Thanks
