Eaglesfly
(Junior Member)
06/30/15 09:32 AM
AC Line Options
I'm searching for a line that will connect to the high side of the compressor to run to my aftermarket universal condenser. Does anyone have a closeup picture of the end of the line that attaches to the compressor? Anyone know if a line from another vehicle will fit the compressor high side? I'm not concerned about what the rest of the line looks like; it will be modified to a universal #8 end for my application.
(Turn Right Racing)
06/30/15 01:04 PM
Re: AC Line Options
If you don't find one used (I have seen your other posts for parts), I am sure in Florida you could find a a/c shop that could make one up for you. Fittings and hoses are pretty standard, just need the crimper.
Eaglesfly
(Junior Member)
06/30/15 01:07 PM
Re: AC Line Options
That's my plan, however I do need to provide the block that attaches to the compressor. This is where I'm stuck right now. I'm trying to figure out if the port is the same on newer Galants and if so, I can grab one of those from a local yard to use just the block to connect to the port on the compressor.
89Mirageman
(It's no Mirage, man)
06/30/15 07:55 PM
Re: AC Line Options
I answered your WTB as well but if you just need the end I probably already have that here. 89-92 colts and mirages use the same compressors as the GVR4 and I'm sure I have some spare lines for it.
Eaglesfly
(Junior Member)
06/30/15 08:24 PM
Re: AC Line Options
That's exactly the information I was looking for.
