jepherz
(Too Clean)
04/30/08 06:29 PM
Master bushing list
Energy suspension:
(R - Red, G - Graphite)
Stock front swaybar/endlink bushings (Kit, 20mm) - 5.5106R - $12 - Ref.
Front subframe bushings (Kit) - 5-4105G - $?? - Ref.
Front control arm bushings (Kit) - 5.3108 - $35
Rear control arm bushings (Kit) - 5.3113 - $35
+ Rear trailing arm bushing - 2126 or 2176 - Img
+ Upper control arm bushing - 3174 and 3175 - Img
+ Lower control arm bushing - 2148 (2x) - Img
Stock rear sway bar/endlink bushings (Kit, 20mm) - 5.5108 - $18
Trailing arm bushing - 5.7106
Rear upper arm bushing - 5.3109
Noltec:
Rear mustache brace busings - N92170 - $95 - Ref.
Whiteline:
Front caster bushings - ??
Rear camber bushings - KCA365 - $66 - Ref.
Front adjustable endlinks - ??
Prothane:
Motor mount inserts (Kit) - 131902 - $68
Boostx:
Rear subframe bushings - Ref.
*All prices are approximate and cited from reference.
jepherz
(Too Clean)
05/23/08 02:51 PM
Re: Master bushing list
Additional info:
JSchleim18
(Minor 69er)
01/22/10 12:06 PM
Noltec N62168 - Stub Axle to Chassis Bushings
Whiteline KCA365 Rear Upper Control Arm Bushings (Camber adjustable)
Whiteline KCA321 Front Lower Control Arm REAR Bushings (Caster adjustable)
Whiteline W0623 Rear Lower Control Arm Inner Bushings (Same as Superpro SPF1438K)
Whiteline 3MR60XXZ 26mm Rear Swaybar Bushings
Whiteline BMF60 22mm Front Swaybar Bushings
Boostx Custom Mustache Brace and Rear Subframe Bushings (Larger bushings are rear subframes)
