Mitsubishi OEM Turbo Specifications Flow Rates @ 15psi: TDO4-9B-6CM2 265 CFM TDO5-12A-8CM2 320 CFM TDO4-13G-5CM2 360 CFM TEO4-13C-6CM2 360 CFM TDO4L-13G-6CM2 360 CFM TDO4L-15C-8.5CM2 390 CFM TDO5H-14B-6CM2 405 CFM TDO5H-14G-8CM2 465 CFM TDO5H-16G-7CM2 505 CFM TDO5H-16G-10CM2 505 CFM TDO6-17C-8CM2 550 CFM TDO6H-20G-14CM2 650 CFM TDO7S-25G-17CM2 850 CFM TFO8L-30V-18CM2 1200 CFM Max Output: TD05-14B (stock 1st gen) 275-300hp @ 21 psi TD05-16G (small) 345-365hp @ 22 psi TD06-16G (large) 365-385hp @ 22 psi TD06-20G 430-450hp @ 22 psi T25 (stock 2nd gen) 235-250hp @ ?? psi T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi Evolution 1 Turbo = TDO5H–16G-7 Nozzle Area (cm2) = 7 Exhaust turbine = Inconel (steel alloy) Compressor = Aluminium, 60mm wide Evolution 2 Turbo = TDO5H–16G-7 Nozzle Area (cm2) = 7 Turbine = Inconel (steel alloy) Compressor = Aluminium, 60mm wide Evolution 3 Turbo = TD05H–16G6-7 Nozzle Area (cm2) = 7 Turbine = Inconel (steel alloy) Compressor = Aluminium, 68mm wide Evolution 4 Turbo = TD05HR-16G6-9T Nozzle Area (cm2) = 9 Turbine = Inconel (steel alloy) Compressor = Aluminium, 68mm wide Evolution 5 Turbo = TD05HR-16G6-10.5T (GSR) TD05HRA-16G6-10.5T (RS) Nozzle Area (cm2) = 10.5 Turbine = Inconel (steel alloy), Titanium alloy (RS) Compressor = Aluminium, 68mm wide Evolution 6 Turbo = TD05HR-16G6-10.5T (GSR) TD05HRA-16G6-10.5T (RS/rs2) Nozzle Area (cm2) = 10.5 Turbine = GSR - Inconel (steel alloy), Titanium alloy (RS/RS2) Compressor = Aluminium, 68mm wide Evolution 6 : Tommi Makinen Edition Turbo = TD05RA-15GK2-10.5T (GSR) TD05HRA-16G6-10.5T (RS/rs2) Nozzle Area (cm2) = 10.5 Turbine = Titanium alloy for both RS/RS2/GSR! Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide Evolution 7 Turbo = TD05HR-16G6-9.8T (GSR) TD05HRA-16G6-9.8T (RS/RS2) Nozzle Area (cm2) = 9.8 Turbine = GSR - Inconel (steel alloy), RS/Rs2=Titanium alloy Compressor = Aluminium, 68mm wide Evolution 7 GTA Turbo = TD05-15GK2-9.0T Nozzle Area (cm2) = 9.0 Turbine = Inconel (steel alloy) Compressor = Aluminium, 65mm wide Evolution 8 Turbo = TD05HR-16G6-9.8T (GSR / USDM) TD05HRA-16G6-9.8T (RS/RS2 & NZDM) or 6MT:TD05HRA-16G6-10.5T (model unknown) Nozzle Area (cm2) = 9.8 Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy), RS=Titanium alloy. Compressor = Aluminium, 68mm wide Evolution MR aka "8.5" GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option) RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed) Compressor = Aluminium, 68mm wide Evolution 9 USDM & JDM = TD05HRA-16G6C-10.5T Turbine: GSR / GT = Inconel alloy, RS = Titanium alloy Compressor: GSR / GT = Aluminium, RS = Magnesium Alloy |
Only 2 errors that I can see; the Lancer Evo 1 and 2 came with a big 16g stock (as did the VR4 Evo), so the comp wheel should read 68mm for those, and not 60mm. It's a common mistake that seems to have taken root for some reason. The only difference between the Evo 1/2 16g and the one on the Evo 3 is the design of the comp wheel (same dimensions of the exducer, though), and the use of lighter materials for manufacture. Other than that, it's all good stuff ![]() |
Also you have the Evo 3 turbo listed as a 16G6. I think the extra six means it spins backwards like all the later Evo's and as we all know it spins the normal way and will fit on GVR4's and DSM's. |
No, TD05H–16G6-7cm is the correct designation for the Evo 3 turbo. The letter 'R' on the Evo IV onwards turbo's indicates a 'reverse-spinning' turbine. |
I don't think so, Usually we call TD05H–16G6-7, evo3. check the popular compressor map below: |
Which cars came with the TD05H 14g with 8cm housing? I assume that being "g" bladed and td05, you would be able to use the 8cm housing with a 16g wheel... |
the vr4 evo came out with a small 16g not big 16g, same as the early evo's (1/2) |
