Luke
(Senior Member)
06/17/05 09:59 AM
FREE mod: short-throw shifter
Simply drill and tap on the shift lever closer to the pivot point.
I moved inwards by about 33% or so, resulting in 33% shorter throw back-and-forth in the cabin.
I used "8mm X 1.25" which matches perfectly with the diameter of the stock pin.
You will also need to make the rubber-stopper thicker in the shifter base. Otherwise, you run the risk of breaking your shift fork when you shifting hard.
I have run with this mod for almost 2 years, and no issue.
mistaVR4
(Rest in Peace)
06/17/05 10:35 AM
Re: FREE mod: short-throw shifter
Thats pretty cool man! Can you get a pick of the thicker rubber stopper you put in the shift base also.?
Thanks,
-Steve
bazeng
(work in progress)
06/17/05 05:47 PM
wicked!!!
Luke
(Senior Member)
06/17/05 08:18 PM
For the bump stopper on the shifter base, simply cut a small section of a hose and zip tie around the stock stopper to make it thicker.
Like so..
Luke
(Senior Member)
06/17/05 08:20 PM
In addition, to install a leather shift boot, you can reuse the bottom portion of your old accordion-style rubber boot.
Like so.
What the shifter looks like:
**DONOTDELETE**
(Unregistered)
06/19/05 01:02 AM
Thats pretty cool Luke,
How far down the shift lever do you drill the hole. like a 1/2 inch or somthing
Luke
(Senior Member)
06/19/05 01:22 AM
I drilled it all the way through, and also tap it all the way through the lever.
Then I use a bolt, a washer, and a nylon lock-nut at the bottom..
I will try to take a picture of this.
The bolt does not clamp down on the shifter bushings.
The lock-nut at the bottom of the lever kinda acts like a jam nut.
**DONOTDELETE**
(Unregistered)
06/19/05 06:32 AM
MODS: Can you make this one a sticky in the "how to section?"
Ian M
(waiting for the bus)
06/19/05 09:22 AM
Here is another similar,with adjustable shift stops,off VFAQ.com:
http://mario.germain.com/shifter.html
