**DONOTDELETE**
(Unregistered)
04/12/05 11:40 AM
CAPS Requests
Mods feel free to move this if you need to a different forum.
Okay I've got CAPS up on my work computer (finally) so I can run searches for people. I'm going to try to get common VINs posted here as it makes it easier to search but if the part is not off a DSM then please be as specific as possible. I make no guarantees the part number is correct but I'll try my best. Let me know as well if the PN was wrong so it doesn't get archived as this thread progresses.
HertzGalant VR4.org Administrator
(OneTitle to rule them all.)
05/06/05 08:36 AM
Re: CAPS Requests
This is certainly a good idea, but not a lot of contributions so far.
steveGalant VR4.org Administrator
(Key Fob Guy)
05/06/05 08:39 AM
Re: CAPS Requests
I never noticed this. I have CAPS set up at work too, so I'll do what I can to help out.
**DONOTDELETE**
(Unregistered)
05/09/05 06:22 PM
Re: CAPS Requests
Looking for part number for rear wheel bearing(s) VIN JA3CX56U5NZ007219
Also is it two separate bearings for each wheel - or one complete unit with bearings enclosed?
much appreciated
**DONOTDELETE**
(Unregistered)
05/09/05 07:19 PM
Re: CAPS Requests
Steve I believe that I have a spare set of rear wheel bearings. I'll look up the part numbers tomorrow.
-Paul
atc250r
(Senior Ricer)
05/10/05 06:03 PM
Re: CAPS Requests
They are two seperate bearings:
MB290175
MB569972
There are also a seal, a cover, and a "rotor".
John
**DONOTDELETE**
(Unregistered)
05/10/05 07:44 PM
Re: CAPS Requests
is the rotor a unit that contains the two bearings? Part # ?
Seals & cover too (might as well)
**DONOTDELETE**
(Unregistered)
05/11/05 06:40 AM
Re: CAPS Requests
Here you go:
34068 MB393807 DUST SEAL,RR AXLE SHAFT,INR
33103 MB290175 BEARING,RR AXLE SHAFT,BALL,16X58 REPL PART MT191613
33138 MB534782 ROTOR,RR AXLE SHAFT
33105 MB569972 BEARING,RR AXLE SHAFT,OTR,BALL,72X17-35
33108 MB290428 COVER,RR AXLE SHAFT,INR
33109 MB393803 COVER,RR AXLE SHAFT,OTR
33136A MB569254 SHAFT ASSY,RR AXLE
Pick and choose away.
twkd
**DONOTDELETE**
(Unregistered)
05/12/05 11:12 AM
Re: CAPS Requests
Could someone with good CAPS skills and a jdm copy find every vehicle this part number was used on?
MB860149
gear kit, rear diff final 3.909
It may help some people stuck with the RS/EVO gear box.
3Diamond
(Hampster Powered and In the "Private" clan !)
05/16/05 11:59 PM
Re: CAPS Requests
OK this is a wierd one but i will be soo grateful if someone could help me out!!
Car is a Galant 1991 FWD I need illustration and part numbers for REAR bearings and fronts (if not too troubling). It came with same rotors/ebrake combo on the rear as did VR4 so-its not the DRUM version as apparently the bearings are different.
THANKS!
3Diamond
06/20/05 01:33 PM
Re: CAPS Requests
anyone? All i need are the inner, outer bearing #'s. Thats a USDM, galant SOHC 1992, WITH disc, not drum rear brakes (look like our vr4).
**DONOTDELETE**
(Unregistered)
06/23/05 06:41 PM
Re: CAPS Requests
Can someone give me the part number to a passenger side manual steering rack bracket? Just the bracket...thanks a ton
**DONOTDELETE**
(Unregistered)
06/24/05 06:01 AM
Re: CAPS Requests
About 3.9 rear diff gear set:
P/N MB860149 was used on:
CD9A, CE9A (Evo2 & Evo3 Lancers)
E38A, E39A, E74A, E84A (JDM Galants VR-4 different generations)
N23WG (Mitsubishi RVR - some kind of RHD Expo LRV but with turbo and GVR4 RS tranny :-) )
**DONOTDELETE**
(Unregistered)
07/18/05 08:22 AM
Re: CAPS Requests
Sorry I haven't checked this thread in awhile. I'll try to see if I can find the info that some people were looking for on CAPS.
**DONOTDELETE**
(Unregistered)
08/17/05 09:35 PM
Re: CAPS Requests
anyone knows where i can get a CAPS program?
atc250r
(Senior Ricer)
08/17/05 10:06 PM
Re: CAPS Requests
It's in the How-To section of the board.
John'
Bimmubishi
(giant log)
08/22/05 07:48 PM
Re: CAPS Requests
Rear O2 sensor for Evolution II CE9A (2 wire)
Thanks homeys.
**DONOTDELETE**
(Unregistered)
09/10/05 05:30 PM
Re: CAPS Requests
part # for CAS plug harness, please. 91 GVR4
Thanks.
-Ryan
Bimmubishi
(giant log)
01/24/06 08:57 AM
Re: CAPS Requests
Looking for someone with a relatively new CAPS to look up the following:
Evo 7 (Ct9A) front lip (3 pcs I think)
Evo 7 Wheels (BBS)
Evo 7 Rear bumper
Thanks guys, I need the part numbers too. My caps is not at the shop so I can't look it up for someone.
AL
speedyvr4
(Still looking for the forest!)
01/25/06 07:49 PM
Re: CAPS Requests
my caps wont recognize ct9a,infact there is no evo to choose from,i guess i have usdm caps.I just got it so bear with me,if you can tell me what to put in the cells or give me a VIn i can give it another shot.
Bimmubishi
(giant log)
01/25/06 08:17 PM
Re: CAPS Requests
Same with my caps, that's why I had to post.
Thanks for the try though.
A
atc250r
(Senior Ricer)
01/25/06 08:19 PM
Re: CAPS Requests
You're probably going to need the JDM CAPS since the 7 was never a USDM car. I don't have that on my PC. Hell, my CAPS CD doesn't even have the Evo8 on it .
John
powerplay
(Yes Man)
01/25/06 09:42 PM
Re: CAPS Requests
Alex, I checked my USDM CAPS and no Ct9A, but I thought you had a working JDM CAPS program?
JB
(Other)
01/26/06 08:28 AM
Re: CAPS Requests
Mine has ct9a, but it only lists the 03-05's fed cars(rs, mr, and gsr)
**DONOTDELETE**
(Unregistered)
01/26/06 08:56 AM
Re: CAPS Requests
good luck finding JDM caps, i know you can get books from mitsu that have all the JDM Evo part #'s.........the 3 book set is like $900.....if you need part #'s from something newer i work at a dealer so i always have newest version of caps
01/26/06 10:09 AM
Re: CAPS Requests
PM the "man" with a Datsun.
**DONOTDELETE**
(Unregistered)
02/12/06 09:08 AM
Re: CAPS Requests
Nuts / bolts / washers for 4-bolt axle cups. I have a 4-bolt rear, with
brand-new cups, but no bolts/nuts to connect it to the wheel.
Need part #'s for these. Also, are they the same as the 3-bolt hardware ?
Or do I need to buy 8 sets ?
atc250r
(Senior Ricer)
02/12/06 12:57 PM
Re: CAPS Requests
The bolts from the 3 bolt set up work fine, I then used a generic bolt that we had in the shop hardware bins. The bolt is a 10mmx29mm so a 10x30 will work. Here are the part numbers in case you are not willing to go the route I did:
MB160664 - Bolt
MS450043 - Washer
MF430122 - Nut
**DONOTDELETE**
(Unregistered)
02/14/06 05:15 AM
Re: CAPS Requests
Thanks...very helpful. Appreciate it.
**DONOTDELETE**
(Unregistered)
03/06/06 10:29 PM
Re: CAPS Requests
Anybody know the part number for the check valve for a 91 Tsi AWD?
atc250r
(Senior Ricer)
03/07/06 09:52 AM
Re: CAPS Requests
Sorry, you need to be more specific than "check valve".
John
**DONOTDELETE**
(Unregistered)
03/09/06 07:16 AM
Re: CAPS Requests
The little blue cylinder-like one that's right above the plate that the fuel pump is attatched to, the plate that bolts down in the hole in the trunk. It's got hoses attatched on each side, one hose on the front side, other on the rear. If that description sucks, let me know, I can get a picture of it.
**DONOTDELETE**
(Unregistered)
03/14/06 10:54 AM
Re: CAPS Requests
can someone check a temp sensor #, my Napa part # crosses into a MD069879, but sometimes my interchange isn't great, so if someone could check that'd be great.
Thanks,
Mark
powerplay
(Yes Man)
03/14/06 01:24 PM
Re: CAPS Requests
Mark,
MD069879 Sensor Unit,Water, list $43.40 cost $33.07
Is this what you wanted to know?
**DONOTDELETE**
(Unregistered)
03/14/06 03:02 PM
Re: CAPS Requests
yes, thankyou very very much
**DONOTDELETE**
(Unregistered)
04/14/06 07:48 AM
Re: CAPS Requests *DELETED*
Post deleted by 1778
**DONOTDELETE**
(Unregistered)
04/22/06 02:22 PM
Re: CAPS Requests
Okay, it's not for a Galant, but I just can't seem to find the part number.
Need an axle shaft seal for a 1995 Mirage 1.5L automatic. Driver's side.
I guess I should find myself a copy of CAPS. Probably wearing out my welcome with part # requests.
quasimondo
(Running on Empty)
04/23/06 11:28 AM
Re: CAPS Requests
What's the part number and price for #5?
atc250r
(Senior Ricer)
04/23/06 11:34 AM
Re: CAPS Requests
Do you need the gear or just the shaft?
John
quasimondo
(Running on Empty)
04/23/06 11:48 AM
Re: CAPS Requests
Just the shaft. The splines are all stripped out.
**DONOTDELETE**
(Unregistered)
04/23/06 12:43 PM
Re: CAPS Requests
Got myself a copy of CAPS. Part was MD707184.
**DONOTDELETE**
(Unregistered)
04/23/06 01:03 PM
Re: CAPS Requests
I'm new with CAPS, but if you are looking for #30452 in the picture
above, the part is: MD741189 SHAFT, T/F DRIVE GEAR
quasimondo
(Running on Empty)
04/23/06 05:35 PM
Re: CAPS Requests
Do you have a price for that part?
atc250r
(Senior Ricer)
04/23/06 05:40 PM
Re: CAPS Requests
Try mitsubishiparts.net for a price and then order from Josh .
John
Bimmubishi
(giant log)
05/02/06 09:39 AM
Re: CAPS Requests
Can someone look up an O2 sensor for CE9A Lancer Evolution II. Looking for the 2 wire version. Can't find it in caps. Probably cause I type with one finger on the board and one in my nose.
Alex
KT
(Turbotoolbox)
06/05/06 06:59 AM
Re: CAPS Requests
I'm doing the 4 bolt swap and 5 lug hub conversion. I've got the bearing P/Ns for the rear, but need the P/Ns for the bearings and dust covers up front. Thanks. KT
a_santos
(Brasileiro Turbinado)
06/08/06 04:29 PM
Re: CAPS Requests
Can someone look up to see if a 4g64 head gasket is the same as a 4g63 gasket.
thank you
**DONOTDELETE**
(Unregistered)
06/12/06 08:44 AM
Re: CAPS Requests
Looking for the part numbers for the double 3rd and 4th syncros and gears from the evo3 trannies.
I dont have JDM caps.
**DONOTDELETE**
(Unregistered)
06/13/06 10:31 PM
Re: CAPS Requests
I need help finding a new engine trans combo for my 92 galant vr4. Any info would be a help. If I can't find one it is out the door with the vr4. But that would suck.
**DONOTDELETE**
(Unregistered)
08/06/06 11:35 AM
Re: CAPS Requests
Need CAPS for the following items:
1. Piston & Pin / Piston Ring
2. Rear Brake Caliper & Rotor
Thanks.
**DONOTDELETE**
(Unregistered)
08/28/06 06:21 AM
Re: CAPS Requests
Anyone know the part# for rear sway bar links??
mysticj
(Newbie)
11/03/06 02:03 PM
Re: CAPS Requests
VIN: 4A3AJ56L2RE111727
Camshafts
**DONOTDELETE**
(Unregistered)
11/03/06 02:09 PM
Re: CAPS Requests
inlet md193628 which superseeds to md335760
exhaust md190853
b00st33d
(Member)
04/30/07 12:04 PM
Re: CAPS Requests
I need part # for the half shaft seal to the transmission.
Thank you.
Scott Y
(mighty skunk hunter)
05/24/07 08:52 PM
Re: CAPS Requests
Need to know if the lower passenger rear control arm is the same between a 1G and GVR-4. Mine has a corkscrew twist in it and needs to be replaced.
12/26/07 05:49 PM
Re: CAPS Requests
CAPS online e39a
**DONOTDELETE**
(Unregistered)
12/28/07 12:09 PM
Re: CAPS Requests
Have CAPS and cannot figure this one out - went to dealer and they gave me wrong part, and they have CAPS too! Go figure. The problem is, it is on two different pages. Someone help!
The struts on our cars have two bolts. The upper one is shorter and skinnier. The lower one is longer and fatter. I need the number for the upper one. We had an alignment done and the shop took the original and replaced it with an eccentric bolt to be able to better align the caster after the wrecked side got pulled out. And they kept it.
I have bought the lower, fatter one which I don't need.
HunterDG
(Junior Member)
01/05/08 08:22 PM
Re: CAPS Requests
CAPS online e39a
guys, maybe i'm missing something, but the above link is to the Asian E39a
the American e39a is here: American E39a
there are both California and Federal emissions versions (CAL vs FED)
BoostedAWD91
(Senior Member)
01/14/08 09:32 PM
Re: CAPS Requests
i need the part # for the brake master cylinder bracket
FlyingEagle
(Eager Beaver)
02/03/08 04:55 PM
Re: CAPS Requests
CAPS online e39a
I've never had the links be able to load, I keep getting a message like 404 Not connected to the net. What gives, because I never have a problem unless a picture is blocked, but I would get a banner saying so. Any thoughts, because I would like to see the online CAPS setup.
Scott Y
04/26/08 01:38 AM
Re: CAPS Requests
I need the temp sensor for the single-wire that goes on the back side of the thermostat. Not the AC one up top, not the ECU or the gauge ones on the front.
mysticj
(Newbie)
05/13/08 08:17 AM
Re: CAPS Requests
Pistons
kitcho
(I'm A Canadian)
07/16/08 01:27 PM
Re: CAPS Requests
for someone with JDM caps, I want to know the PN for the screws that hold in the foglights (for the projector fogs). the factory ones are stainless and i'd like replacements.
thanks
Scientist
(Secretary of the Interior)
01/30/09 12:41 PM
Re: CAPS Requests
This is for the Inside screw MB645509
Inside Screw: MB645510
wowzer
(Master Mechanic-Will Travel)
02/05/09 09:05 AM
Re: CAPS Requests
Looking for a control arm with bushings in it?
Generated in 0.008 seconds in which 0.004 seconds were spent on a total of 4 queries. Turbo powered.
