**DONOTDELETE**
(Unregistered)
11/07/04 08:58 PM
Steve Joo's 1992 Galant VR4
872 of 1000
Mods:
Exterior
JDM clear corner lights
JDM AMG Galant Grille
Electronics/Performance Modfications
HKS EVC 3
HKS VPC with 550cc injector chip
A'PEXi S-AFC
Blitz Nippondenso 660cc fuel injectors
Walbro GS255 fuel pump
Fuel pump rewired
Adjustable Fuel pressure regulator
Keydiver Modified ECU to handle 660 cc maps, raised rev limit
Engine
Rebuilt head
HKS metal head gasket
8.5:1 95 pistons
Windoweld reinforced motor mounts
K&N 3" cone filter
Dejon Tools 3" intake
Road///Race Engineering Intercooler Piping
Mitsubishi Lancer Evolution III Intercooler with enlarged Outlet
TAS crushed blow-off valve vented to atmosphere
Turbocharger/Exhaust
TRE ported TDO5-20G turbo
TAS ported 2G manifold
TAS ported Lancer Evolution III O2 Housing
Road///Race Engineering Stainless Steel Oil Feed Line
Road///Race Engineering 3" Downpipe
Road///Race Engineering 3" Catalytic Converter
Fujitsubo Legalis R stainless JASMA exhaust
Drivetrain
Stock Transmission
C's Short Shifter
Modified shifter bushings (similar to Symbroski kit)
Road///Race Engineering stainless steel clutch line
Road///Race Engineering lightened flywheel
1993 Eclipse GSX 4 bolt rear-end with LSD
3Speed stainless steel scattershield
ACT 2600
Suspension
Ground Control Coilovers
Cusco front camber plates
KYB AGX shocks
Whiteline rear 26mm sway bar
Greddy Strut Bar (front)
Mofugas Whiteline full polyurethane bushing kit
Noltec rear mustache bar polyurethane bushings
Energy Suspension subframe bushings
New Mitsubishi swaybar endlinks (f/r)
4 Wheel Steering eliminated
1993 Mitsubishi Eclipse GSX power steering reservoir
1993 Mitsubishi Eclipse GSX 5 lug
1995 Mitsubishi Eclipse Wheels
Brakes
Stainless steel braided brake lines
Porterfield R4S Front Pads
Misc
Momo Monte Carlo Steering Wheel
HKS Turbo Timer
Slimline SPAL fan
Odyssey battery relocated to trunk with fuse and distribution block
89' "under the steering wheel panel"
Omori 60mm Boost & Egt
1g Master cylinder
66k Miles
Generated in 0.003 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
