Owner: Blake Adams Location: KC, MO Message Board Name: badams Year: 1992 Number: 50/1000 Best 1/4 mile time: N/A Dyno: N/A Build thread: 50/1000 Motor: • 6 bolt stock block • Stock cams • Gates timing belt • Gates accessory belts • OEM Mitsubishi hydraulic tensioner • New water pump and timing components (Gates) • NGK BR7EIX plugs • Custom billet aluminum Galant VR-4 oil cap by Jason Everts Fuel: • Walbro 255 fuel pump • Aeromotive A1000 AFPR (set @ 43.5 PSI BFP) • Deatschwerks fuel pump hardwire kit • -6 AN feed line to rail • New OEM fuel filter • FIC 1050cc injectors Intake & Intercooler: • ETS bar and plate FMIC 24” x 10” x 3” • 2.5" intercooler piping • Custom 2.5" intake pipe • K&N 2.5" high flow air filter (RU-4950) Turbo & Exhaust: • Big 16G turbo • Ported stock O2 housing • 2G OEM exhaust manifold • CMP 2.5" turbo back exhaust Cooling: • OEM radiator • Stant 13lb radiator cap • Stant 180* T-stat • Factory puller main fan • Factory pusher A/C fan Interior: • Personal steering wheel and shift knob combo • Paulo fiberglass dual gauge pod • VDO gauges (volt, boost) • Turboflanagan custom floor mats • CDA-9856 EMS, Logging & Electronics: • ECMlink V3 full (tuned on speed density) • Innovate LC-2 wideband • Omni Power 4 bar MAP sensor • GM IAT • NGK plug wires • ECMlink boost control setup Drivetrain: • Stock transmission (Red Line MT-90) • B2B 3 bolt non-LSD rear (Red Line Heavy ShockProof) • 23 spline transfer case (Red Line Heavy ShockProof) • EHmotorsports short shifter • ACT 2100 pressure plate (MB010) • ACT Sprung 6-Puck Race Disc (6224704) • Competition Clutch lightweight steel flywheel • OEM release bearing • FTP stainless steel braided clutch line Brakes, Wheels & Suspension: • BC BR series coilovers • Cusco front and rear strutbars • Tuner lug nuts • BBS wheels * 16x7 * 4x114.3 * Offset 44 • Dunlop Direzza DZ102 tires 215/50 R16 • 2 pot GVR-4 front calipers • JMF aluminum brake fluid reservoir cap • Stoptech slotted front & rear rotors • Akebono brake pads • Techna-fit brake lines on all 4 corners |
