Owner: Luis Rosil Location: Stockton, CA Message Board Name: Year: 1991 Number: 1415/2000 Mileage: 210,xxx Dyno : 324 HP/360 TQ @ 20 PSI Best 1/4 mile time: None yet Build Thread Dyno Everything was done on the car at 183,642 miles unless otherwise noted. Engine: 2g pistons/1g rods evo 8 valves, springs & retainers MLS head gasket arp head studs re-torqued at - 207,321 miles revised 3mm lifters - 186,231 miles BSE Kit Forward facing oil filter housing Unorthodox Aluminum Crank Pulley - 194,543 Prothane Red Motor Mounts HKS Clear Timing Cover Mishimoto catch can - 207,321 miles Black Top CAS - 202,136 miles SS oil feed line - 207,321 miles Larger oil return line - 207,321 miles Custom water pipe - 207,321 miles SS valve cover bolts - 207,321 miles BC 272 Camshafts - 210,000 miles Fuel & Ignition: Custom trunk battery tray - 202,231 miles D-51 series Optima Yellowtop - 201,642 miles AEM 340 in tank fuel pump - 202,136 miles Fuel pump re-wire denso 780cc injectors Injector seals and cleaning - 207,321 miles full throttle FPR w/ gauge -6 AN line from filter to rail - 207,321 miles Russell Fuel filter - 207,321 miles NGK Copper BPR8ES - 207,321 miles SS fuel rail bolts - 207,321 miles 92 octane Intake & Exhaust: Ported Evo 3 exhaust manifold - 207,321 miles Exhaust manifold studs - 207,321 miles PTE SCM 6152E - 210,000 miles ARP manifold to turbo bolts - 207,321 miles 3" intake - 207,321 miles Punishment racing EW with Tial WG - 207,321 miles Titanium Heat wrapped down pipe - 207,321 miles 3" turbo back exhaust, W/ V-Band clamps, Vibrant muffler - 207,321 miles JM Fabrications SMIM - 210,000 miles Thermal throttle body and intake manifold gaskets - 207,321 miles 1G ETS race intercooler - 207,321 miles Tial 50mm BOV - 207,321 miles 2.5" aluminum intercooler piping made to be as short as possible GM IAT OMNI 4 bar MAP sensor IR boost controller(linked into ECMLink) S90 3" throttle body - 210,000 miles FIAV block off - 191,943 miles New Biss with o-ring all new gaskets - 207,321 miles full OEM heat shields - 207,321 miles Misc. SS bolts - 207,321 miles Drivetrain: short throw shifter Rebuilt shifter assembly - 202,467 miles Hardened washers for shifter base - 202,467 miles Fresh Clutch fluid - 207,321 miles OEM Throw-out bearing - 202,467 miles Shep Stage 1 transmission - 207,321 miles FX 2200LB PP - 202,467 miles FX Multi-friction Race disc - 202,467 miles resurfaced ACT aluminum flywheel - 202,467 miles apr flywheel bolts rebuilt driveshaft w/ carrier bearings 186,973 miles Redline 75w90 & heavy shockproof - 207,321 miles Front Axles - 207,321 miles SS clutch line - 207,321 miles rebuilt slave and master - 207,321 miles 4 bolt rear end in 4WS housing - 207,321 miles 5 lug conversion - 207,321 miles Cooling: Sirocco radiator - 207,321 miles Mishimoto high flow fan - 207,321 miles AISIN OEM water pump - 195,785 miles 180 degree thermostat - 207,321 miles Mishimoto Radiator Hose - 199,532 miles Greddy radiator cap W/ push release - 205,345 miles fully flushed and back flushed system - 207,321 miles Misc. SS bolts - 207,321 miles Suspension & Handling: 4ws intact Megan Racing Coilovers - 210,000 miles whiteline 26mm rear sway bar W bushings- 207,321 miles Energy bushing kit Stock rear pads - 191,943 miles Front and rear rotors - 207,321 miles Cusco front and rear strut bars - 207,321 miles All 4 corner Wheel Bearings - 207,321 miles Moog Steering rack boots - 201,421 miles Moog sway bar end links - 201,421 miles Energy Front Sway bar bushings - 201,421 miles Energy tie rod and lower ball joint caps - 201,421 miles Non-ABS proportioning valve - 201,421 miles Rear Adjustable Control Arms - 206,200 Rear Lower Control Arms - 206,200 Rear Moog Sway Bar Endlinks - 206,200 8G Galant Master brake cylinder - 206,200 Rims & Tires: 17" 5 lug enkei race rims with Bridgestone potenza tires - 207,321 miles 17" Evo 8 enkei rims - 210,000 miles Gauges & Tuning: Autometer Z-Series Boost Gauge - 206,200 Autometer Z-Series Oil Pressure Gauge - 206,200 Innovate LC2 Wideband - 208,000 miles Blitz TT in underdash pocket ECMLink V3 on S/D Audio: Pioneer Headunit w/ AUX JL Audio rear deck and door speakers Rockford Fosgates in the dashboard Interior: custom floormats EVO 8 front and rear seats 4 point racing harnesses Nardi steering wheel freshly dyed carpet Custom Cluster surround gauge pod 89 underdash with pocket Refurbished stock 1g shift boot - 201,421 miles Rear deck dyed black Rear Speaker covers replaced with Misfits Cloth 89 Manual Seatbelts threespeed harness bar - 202,467 miles 89 Glove Box - 206,200 replaced headliner - 207,321 miles Exterior: JDM Front Bumper - 202,477 miles JDM Rear Bumper - 201,421 miles JDM RS Hood JDM Rear 1/4 Windows EDM Amber Corners - 204,389 miles JDM Door Stickers Removed wing 3rd brake light installed on rear deck stubby non-power antenna 203,432 miles 93 clear headlights - repainted - 202,477 miles Badge Number Sticker 4WS Sticker Rain Guards MMC badge Red VR-4 badge SS fender bolts - 206,271 miles welded sunroof shut - 205,321 miles 5 different grills JDM fog deletes, pre-face fogs and projector fogs Thule Roof Racks The OEM Window Sticker from 138, not from my vin# Paints, oils and other misc. A/C removed Remounted and repaired wiring. All emissions are removed. ABS has been deleted. Front wheel wells re-rubberized. Still Want: Paint Job |
just two quick photos. i need to clean and then take some real pictures of the car. |
