pot
(It's a twee shaker----choot him choot him)
02/04/10 11:29 AM
FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated August 7, 2020
For sale are stock parts removed from a 158K Summit White. Everything offered is in used but serviceable condition.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions unless noted otherwise. I accept all payments via PayPal to: [email protected]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
ENGINE
Engine Mount Bracket (Rear) $20.00
Intake Manifold Support Bracket $15.00
Alternator Bracket $8.00
Cam Gear $15.00
Crank Pulley Bolt & Washer $8.00 *2 available
Crankshaft Sprocket B $15.00
Flange $3.00
Silent Shaft Sprocket $12.00 each
Water Pump Pulley Set $15.00
Throttlebody Ground Tab $3.00
Spark Plug Wire Guide $3.00 each
Aircan Vacuum Line Mounting Bracket $15.00
EGR Valve *3 Galant/1g Available $15.00
Alternator Relay part no MD113566 $8.00
Alternator Pivot Bolt $8.00
Oil Cap $8.00 each *3 Available
Fuel Pressure Regulator *1g Non-Turbo $15.00
Fuel Filter Banjo Bolt $3.00
Banjo Bolt (Oil Feed on Turbo) $5.00 each
Banjo Bolt (Coolant Feed/Drain on Turbo) $5.00 each
Fuel Purge Control Solenoid $20.00
Fuel Purge Solenoid Valve w/ Wiring $20.00
Fuel Pressure Solenoid Valve Wiring $8.00
EGR Control Solenoid Wiring $12.00
Oil Squirter Check Valve $8.00
Fuse Box Fuse *Complete set for engine bay $5.00
BODY
Headlight Relay part no MB183865 $5.00 each
Corner Lamp Spring $5.00
Lower Radiator Hose Clamps $1.00 each
Washer Reservoir Hardware Set $3.00
Hood Switch (Alarm) *Rubber cracked $3.00
Cowl Vent (Passenger Side) $10.00
Trim Panel (Passenger Side) $3.00
Fender Bolts *Summit White $3.00
Horn $8.00
A/C Condenser High Relay $8.00
MAF Intake Hose Clamp $2.00 each
ECU Harness Retainer $3.00
Timer, Defogger Delay part no MB572253 $8.00
Fuel Filter Bracket *2 Available $3.00 each
EGR Line Retainer $1.00 each
Downpipe Mount $3.00
Exhaust Hardware $1.50
Radiator Bracket Bolt Set $1.00
Door Rubber Molding (Body Side) *Set of all four doors $50.00, or $20.00 each
Side Skirt Hardware Set $2.00
Wheel Well Retainer $.50 each
Galant GSX 3rd Brake Light $20.00
Fuel Door Hardware $1.00
Fuel Door Lock Cylinder Retainer $.50
Tailight Cover (Left Side) $10.00
Tail Light Center Section *Passenger side, slight crack $12.00
License Plate Lights $20.00 for pair
Trunk Lid Bracket $15.00 for pair
Trunk Molding $25.00
Trunk Lid Striker $3.00
Trunk Striker Bolts $2.00
Trunk Grommet $1.00 for pair
Rear Bumper Mounting Bracket Set $10.00
INTERIOR
ALDL Cable $25.00
Fuse Panel $20.00
Fuse Puller (Interior Fuse Block) $1.00
Footwell Carpet Clip Set $2.00
Hood Release Assembly $15.00
Dash Speaker Cover $15.00 *For pair
Defogger Switch $ 15.00
Driverside Visor *Mirror cover unattached $15.00
Dome Light *Sunroof model $40.00
Sunroof Control Motor *part no MB549075 $20.00
Sunroof Power Relay part no MB627895 $5.00
Sunroof Adjust Plate $1.00 Each
Radio Antenna Cable $15.00
Buzzer Switch, part no MB802356 $5.00
Ashtray Cover $2.00
HVAC Selector Tab $1.00
HVAC Vent Tab $1.00
Door Card Handle $5.00 each
Door Handle Cover *Rear Driver side sold $3.00 each
Door Light with lens $5.00
Door Sensor $5.00
Control Unit, Door part no MB543647 $10.00
Driver Window Switch Cover $5.00 each
Driver Window Switch Cover $1.00
Control Unit Auto Seat *Part No MB617345 $25.00
Window Switch $12.00 each
Scuff Plate Hardware $2.00
Armrest Stay $15.00
Arm Rest Hardware $1.00
Seat Trim Bolt Cover $1.50 each or $20.00 for full set
Trunk Trim Access $8.00
Tool Bag $5.00 each
SUSPENSION & STEERING
P/S Mounting Bracket $5.00
P/S Pump Mounting Hardware Set $2.00
P/S Heat Shield $5.00
Cruise Control Cable mount *Mounted on Passenger Side $2.00
Front Control Arm to Subframe Bolts $5.00 *Per pair
Front Subframe Lower Plate & Stopper $5.00
Gusset Plate Bolt Set $8.00
4WS Plug *Off the shelf fastener for use in eliminating 4WS $3.00
Front Steering Rack Brackets $15.00
P/S Line Bracket $3.00
P/S Reservoir Mount Bracket $3.00
Upper Rear Control Arm *Only Passenger Side Left $25.00
Rear Suspension Mount Bolt *1 left $7.00
DRIVETRAIN
Driveshaft Hardware Set $3.00
Slave Cylinder Mounting Hardware $1.00
Shifter Bracket Mount Hardware (Lower) $1.00
Shifter Bracket Mount Hardware (Upper) $1.00
Transmission Mount Hardware $2.00
BRAKES
ABS Electronic Control Unit $40.00
ABS G Sensor (Rear) $20.00
ABS Sensor Mount (Front) $3.00
ABS Ring (front) $20.00
ABS Dust Shield $20.00
Parking Brake Stay $5.00
Brake Fluid Level Sensor Wiring $5.00
Brake Fluid Reservoir $15.00
Brake Caliper Brackets (Rear) *Powdercoated Gloss Black $20.00 for pair
(Turn Right Racing)
02/05/10 09:52 PM
Re: FS: Huge Stock Parts Sale
PM sent.
(Turn Right Racing)
02/13/10 07:32 PM
Bump for a good guy.
**DONOTDELETE**
(Unregistered)
02/14/10 04:44 AM
pm sent. thanks
**DONOTDELETE**
(Unregistered)
02/22/10 06:22 PM
Quoting Pot:
For sale are several stock parts removed from a 158K summit white '91 gvr4. Shipping and paypal charges have been included hence my prices. Shipping charges for OCONUS transactions will be handled on a case by case basis.
I will be continually adding parts over the next twenty-four hours therefore if you don't see something your interested in feel free to PM me.
First PM first served and thank you for your time.
28.) TURBO WATER PIPE *2 AVAILABLE $20.00
Looks like the water pipe in the background is a non turbo pipe. If this is true I will take it. PM sent
Gizmovr4
(Member +)
02/25/10 08:43 PM
PM sent
**DONOTDELETE**
(Unregistered)
03/01/10 09:41 PM
payment sent! thanks again.
EMX5636
(Carbon Fiber Cage)
03/02/10 05:12 AM
PM me a Price shipped to 18960 in PA for the black cover CAS. Thanks!
a2vr4
(Boot Strap Bill's boy)
03/02/10 10:13 AM
trunk/gas popper sold
~Brian A. Moreno
**DONOTDELETE**
(Unregistered)
03/02/10 06:43 PM
PM for clock sent.
onesickcrx
(Brother of the Year)
03/08/10 09:59 PM
Whats up with the strut bars are they for sale
BoostedAWD91
(Senior Member)
03/08/10 11:29 PM
pm sent on black top cas and paint
KiNgMaRtY
(Member +++)
03/10/10 11:52 PM
What kind of condition is the power steering rack in? Mileage? Complete with tie rods? PS pump? Do you have the hose the goes from the fuel door to the tank?
PM me if you do
**DONOTDELETE**
(Unregistered)
03/16/10 07:48 AM
got the package!:D bump for a great guy!
AWDnoobie
(Member)
03/27/10 05:55 PM
Im interested in the engine mounts 345, 346 and 347.
**DONOTDELETE**
(Unregistered)
03/28/10 10:24 PM
I'm interested in the coolant overflow. How much shipped to 85714?
AWDnoobie
(Member)
04/04/10 12:47 PM
Hey Pot, do you still have the rear steering rack? If so what kind of shape is it in, looks kind of rusty in the picture. Id like to get a 2nd one to rebuild
**DONOTDELETE**
(Unregistered)
06/16/10 09:45 PM
Hey bro do you still have the vr-4 emblem???????????
**DONOTDELETE**
(Unregistered)
06/16/10 09:47 PM
IF you still have the emblem email me at [email protected] plz
chrisfullwood
(Member +)
06/25/10 12:55 AM
Do you still have the air conditioning system on the car? if so does it work, if not, is it complete and how much thanks.
Chris
**DONOTDELETE**
(Unregistered)
07/02/10 03:11 AM
Do you still have the vr4 emblem
**DONOTDELETE**
(Unregistered)
07/02/10 03:11 AM
Email at [email protected]
or pm
RJ_P
(Newbie)
07/25/10 12:08 AM
Hey, sent payment already for antenna assembly.. Please confirm.
**DONOTDELETE**
(Unregistered)
07/26/10 03:14 PM
pm'ed
**DONOTDELETE**
(Unregistered)
08/11/10 07:44 PM
hyundai valve cver still available??pm sent
SouthCaliVR4
(Gas Analyzer)
08/11/10 10:51 PM
Just a reminder, You where going to send me some pics of the door panels & let me know what you wanted for all four shipped to 92028/Fallbrook Ca.
trunks
(Member +)
09/16/10 06:04 PM
PMed
RyanInWheeling
(Junior Member)
09/17/10 11:45 AM
What about the window control unit
RyanInWheeling
(Junior Member)
09/17/10 01:01 PM
How much for passenger front and driver rear
tinkolby_25
(Junior Member)
10/06/10 02:15 AM
It's a long shot, but you wouldn't happen to have the roof trim would you? Mine is cut up from my roof rack and I'd like to be able to take it off.
Thanks,
Justin
Diego
(Mad Hatter Suite Touche Debackle Guage filled by Justin)
10/26/10 12:13 AM
Pot do you have an alternator, that holds good charge? Lmk in need of one.
twonineseven
(Weird)
11/29/10 04:53 PM
whats the lowest price you would do shipped to 17022 on the blower motor?
**DONOTDELETE**
(Unregistered)
11/29/10 06:19 PM
111.) SPEAKER COVER (DRIVER & PASSENGER) $12.00 each
Can i get a price on both of these shipped to 53217?
tayschells13
(Junior Member)
11/30/10 11:21 AM
hey bud, happen to have a good mpi relay, clutch safety switch(button on clutch pedal), and the harness that leads to the starter?
let me know
thanks!
-taylor
johnnyRacer
(Member +++)
12/14/10 09:15 AM
is the fuel tank in good shape particularly the studs for the fuel sending unit? would you ship it?
**DONOTDELETE**
(Unregistered)
12/26/10 02:11 PM
Hey!
i need one front passenger side 4lug hub
front passenger side axle
shipped to
10 beverly ct
Jackson NJ 08527
please get back to me asap, thanks!
Anthony
**DONOTDELETE**
(Unregistered)
01/02/11 02:08 PM
do u have a ecu?
chrisfullwood
(Member +)
01/29/11 09:30 PM
It looks like some of the pictures got muddled up, but i saw a picture of a radio plate, with a 3 gauge pod adapter plate deal on it. Is that part actually available? i had to make my own, and it sucked...lol but if it is. how much?
thanks
**DONOTDELETE**
(Unregistered)
02/12/11 11:12 AM
Hello there,
I'm interested in the Front calipers. I still have a couple of questions since I'm planning to use the calipers on a volvo project...
1) Will you send to Holland?
2) Is the distance between the caliper mounting holes 130mm? (I've read some calipers have 160mm and I'm looking for the 130mm ones)
3) Finally. Are the calipers compatible with a 300mm rotor?
I'm looking forward for your reply
thnx + grtz Koen
rallyart911
(Junior Member)
02/23/11 06:37 PM
intresting choice for pic's....
paul j
(Member)
03/29/11 11:42 AM
Does "added" mean what is left or what is added to the sold list?
PM sent
**DONOTDELETE**
(Unregistered)
04/14/11 09:18 AM
Interested in the following...
Turbo heat shield (will this fit an Evo3 16g?)
Rear bumper light(red)drivers side if it matters
How much for both shipped to 08527?
Thanks!
AR
[email protected]
**DONOTDELETE**
(Unregistered)
04/14/11 09:50 AM
Kinda random but i'm also interested in...
Two allan head plugs from oil filter housing.
Looking to plug up my AC fan switch, heard they are the same plug besides length?
Let me know if you have any.
AR
1stplacedsm
(Junior Member)
04/14/11 11:21 AM
Pm sent
**DONOTDELETE**
(Unregistered)
04/14/11 03:05 PM
rear calipers and parking brake cables...
Galactica
(Member)
09/06/11 06:29 PM
Do you have a leather shift knob that fits a stock shifter and does the DSM cupholder fit in the VR4 center armrest?? Thanks.
acustark
(Member)
09/17/11 03:39 AM
PM sent
maxash0775
(Member)
11/19/11 03:25 AM
Hello. Are the tool kits complete. If so please pm me total price with paypal and shipping to 93311. Thanks
GVR4_1636
(Junior Member)
12/12/11 11:40 AM
do you have a 91 gvr4 passenger head signal??
citymunky
(Fake Title)
02/14/12 11:09 AM
I need the Hood cable guide, and I also I might need the the downpipe to block Bracket
Also where did you get the black OH-SHIT handles from?
**DONOTDELETE**
(Unregistered)
03/27/12 12:11 AM
Hi Sir,
How much for the 4 door cards plus shipping to Manila,Philippines?
Thanks.
3O3EL0VR4
(Junior Member)
07/29/12 09:18 PM
PM sent
5OF2k
(Member ++)
07/29/12 09:36 PM
Price for sparkplug cover shipped to 80916?
Thanks sir!
5OF2k
(Member ++)
08/01/12 11:15 PM
Payment sent for sparkplug cover! Thanks Pot!!
5OF2k
(Member ++)
11/12/12 10:02 AM
POT! By chance have a passenger kickpanel laying around? You know, the cover for the footwell just forward of the doorjamb? That's the ONLY thing my interior is missing/needing.
Thanks in advance, sir!
-Jake
5OF2k
(Member ++)
11/12/12 03:34 PM
Alright, thanks anyway sir! Bunmp for for yoU!
460GVR4
(Junior Member)
12/11/12 05:28 PM
Payment sent for driver fog bracket and jack panel cover!
Money that should've gone towards emissions and renewal of registration!!!
460GVR4
(Junior Member)
12/26/12 09:41 PM
Hey I totally forgot you have the upper radiator mounts??
dsm10o0
(Member ++)
12/26/12 11:39 PM
Do you havr a 344 front mount bracket?
jai730625
(Newbie)
12/28/12 09:10 PM
Hi..i need the door sensor switch..please email me the price [email protected]
dsm10o0
(Member ++)
01/29/13 12:48 AM
do you have the bottom part for the shifter cable bracket?
jfco
(Newbie)
01/30/13 10:21 AM
Hi sir, I am interested with the following License plate holder, frontbumper under trim for left and right, sunroof plastic trims and seat trim /boltcover need a set for 2 front seats. BTW do you have a wiper arm with the black deflector srewed on it, I am sorry dont know what you call that. Can you give me a good price for all of these stuff. Can you also send me your number so I can call you. Thanks in advance.
GirlyVR4
(Junior Member)
02/11/13 03:49 PM
You have the front motor mount bracket still?
If you do, I'll take it.
Epifool
(Member)
03/11/13 01:20 AM
Wiper guard thing, upper cam gear cover, sparkplug cover??
Epifool
(Member)
03/11/13 09:55 AM
Any caprpet available? Specifically trunk? Or driver/ front passenger door trim? Center dash ac/ heater vent?
VR4_1752
(Member)
04/03/13 02:49 PM
PM sent.
vr44rv
(Newbie)
07/16/13 01:25 AM
Hi sir,
Is that grill still available and possible to post over?
G
(JDM Unit)
08/05/13 09:54 PM
Do you have a good center armrest lid?
992gnt
(Junior Member)
09/03/13 07:27 PM
I saw a post in the WTB section where someone was looking for a radio harness..
TylerAdamson
(circles method)
09/03/13 08:02 PM
Price on the radio plugs and rear exhaust hanger please. Shipped to 52501.
stagen
(Newbie)
12/11/13 06:54 PM
Happen to have the radiator fan wiring? 6 pin plug going to the fan, resistor and temp switch.
G
(JDM Unit)
12/11/13 10:33 PM
Lot's of good parts here.
Redwood
(wannabe king of rednecks)
12/26/13 02:40 PM
hey man you dont have and roof rack parts do you?
totom
(Newbie)
12/26/13 09:46 PM
Dear Pot,
Is it possible to send one of your ashtray to Indonesia? If yes, how much money do you want for it? Thank you very much..
T3mp0r
(Junior Member)
06/19/14 06:04 PM
pm'd
T3mp0r
(Junior Member)
06/20/14 03:12 AM
Payment sent for battery tie-down. Thanks pot!
ExplicitCC
(Junior Member)
07/21/14 01:01 PM
Re: FS: Huge Stock Parts Sale (Updated 21 July 2014)
I'll Take The Engine Oil cap shipped to 92532
dsmguy92
(Newbie)
08/13/14 03:13 PM
Re: FS: Huge Stock Parts Sale (Updated 11 August 2014)
do you still have the parking brake adjustment piece ?
jfco
(Newbie)
09/13/14 01:29 AM
Re: FS: Huge Stock Parts Sale (Updated 7 SEP 14)
Hi pot john here, Just like to inquire if you were able to get the wiper fin attached to the the driver side wiper arm. Thank you.
thruarod
(Junior Member)
09/30/14 10:35 AM
Re: FS: Huge Stock Parts Sale (Updated 29 SEP 14)
There is a 3rd all aluminum a/c line. Its the only one that you don't have pictured. Whats the chances you have that one as well?
91galantvr4_4WS
(Junior Member)
03/04/15 08:40 PM
Re: FS: Huge Stock Parts Sale (Updated February 8, 2015)
I didn't see this on your list but figured it wouldn't hurt to ask if you had a working brake booster for a Vr4? I am needing the AWD/ All Wheel ABS booster. Apparently there are 4 different boosters that went on the car and I'm needing the one I listed last sentence. (MB699345)
Scientist
(Secretary of the Interior)
05/28/15 09:39 AM
Re: FS: Huge Stock Parts Sale (Updated May 19, 2015)
Shifter and Cable Clips to 33166
galant0933
(Junior Member)
05/28/15 01:08 PM
Hi, I'll take the dash screw cover and a clear door lens. Please pm me.
galant0933
(Junior Member)
06/01/15 03:59 PM
Ok, now my list includes the ac tensioner bracket as well.
So dash screw cover, ac tensioner, and clear lens.
Eaglesfly
(Junior Member)
06/16/15 08:35 PM
Re: FS: Huge Stock Parts Sale (Updated June 9, 2015)
Which AC line is the one you have for sale? I'm looking for the line that goes from the compressor to the condensor. I already have the line that runs from the evaporator to compressor and evaporator to drier.
galant55
(Newbie)
08/24/15 02:17 AM
i was interested in the following parts:
1)ETACS control relay module(under speed control module)my dome light doesnt work.
2)gas tank rubber hose(mine is rotten)
3)passenger side door lock security system switch(the yellow tab is broken on mine)
4)left and right rear quarter dog legs (summit white if possible)
also in your parts list:
1)1g turbo outlet pipe (is this for galant vr4 or talon? i need one for a vr4)
2)fps and resistor pack mount
3)intercooler hose bracket
4)battery liner
5)fuel purge solenoid with mounting bracket
6)relay located on rad support (does this include bracket?)
bowler31185
(Junior Member)
08/24/15 09:17 AM
Re: FS: Huge Stock Parts Sale (Updated August 15, 2015)
I am in need of Rear Main Cover and hardware. What am I looking at shipped to 33710? Thanks
kjbtsi6686
(Junior Member)
01/11/16 04:57 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000)
You wouldn't happen to have the side skirts in summit white available would you?
rallyvr4
(Newbie)
02/13/16 04:59 PM
I'm in need of a front sub frame?
dkvr4
(Junior Member)
03/12/16 07:56 PM
pm sent!
bobbybdemented
(Junior Member)
05/15/16 11:12 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW
I need a water pipe for a turbo
pudge76
(wants a running shell)
05/30/16 02:47 PM
Are the water pump pulleys still availble?
Tre3zy
(correct me if im rite...Wyldcarz been rolling hard for a long time)
05/30/16 03:09 PM
looking for hood cushions or stopper basically the 2 big rubber cushion on both edge near the fender... if you have a pair how much shipped to CA? thnx
Mattwood
(Newbie)
05/30/17 08:01 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated 21 May
Do you have this?
DSMguy89
(Newbie)
06/07/17 04:07 PM
I may have a set
Mattwood
(Newbie)
06/26/17 07:58 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated June 23
What's the condition of the back passenger side door!
GTX
(Member)
10/20/17 03:06 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated July 22
Rear suspension trailing arms? both sides
E39_VR4
(Newbie)
04/21/18 10:41 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated April 20th
Do you have the headliner board? I am in dire need. Also, I need the two trim panels at the bottom of the console on each side. Please PM me with price and availability. Thanks!
BluFalcon
(Fantastic Parts Seller)
04/25/18 11:17 AM
PM'ed
pot
04/28/18 09:31 PM
I'm afraid I do not.
E39_VR4
(Newbie)
05/01/18 06:56 PM
Could you keep me in mind if you part another non-sunroof car? Thought mine was a factory power sunroof, but Iceman saw it Sunday, said it was an aftermarket, so I will need a non-sunroof headliner to cut the sunroof hole in. Thanks heaps!
bobdole
(Old member with new to me VR4 and starting over. Respect your elders kids)
04/10/19 08:02 AM
boost solenoid?
pot
04/10/19 12:04 PM
I saw your post on FB and immediately went through my inventory but no dice Charles.
BLUELIGHTSBABY
(Junior Member)
04/17/19 01:56 AM
do you have the driveshafts and carrier bearings
pot
04/17/19 07:20 PM
Yes I have the Driveshafts however they are all disassembled into 3 separate pieces. You will have to purchase new Carrier Bearings if you opt to purchase the shafts.
I can do an easy $100.00 for all 3 pieces shipped to your front door.
HollywoodHalo560
(Newbie)
04/19/19 08:46 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated April 14
Any chance you have the high mount stop light off of the spoiler?
pot
04/19/19 08:06 PM
Iím afraid I no longer have it available.
pot
07/05/19 09:56 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated June 29th
Bump. Plenty of stock parts are still available.
Stevenoly
(Newbie)
07/19/19 09:45 PM
Do you have a shifter assembly? What is the condition of the bushings? I just bought a 88 JDM car and the shifter feels like i'm stirring oatmeal...
pot
07/20/19 03:28 PM
PM sent.
91gvr4NC
(Newbie)
07/26/19 01:41 PM
Happen to have a roof panel w/o sunroof?
pot
06/25/20 08:20 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated June 19, 2020
Weekly bump. Plenty of stock used parts available. For faster service please contact me at: (910) 689-6150.
Generated in 0.009 seconds in which 0.004 seconds were spent on a total of 4 queries. Turbo powered.
