**DONOTDELETE**
(Unregistered)
06/28/06 11:34 AM
FS: Head Porting Services NEW DEAL!!!
Starting to set up package deals. You can also just order individual parts from me or just have me port your head. Its totally up to you. All of these prices are for 4g63's.
Mitsu Valve packages
E-LOY Performance stainless valves
1mm over intake valves
.5mm over exhaust valves
1 set=16 valves 232.00
Super Tech Valves
1mm over exhaust valves which are inconel(can take very high heat)
1 set=16 valves 332.00
Bronze valve guides=set of 16 72.00or4.50 each
Set of 16 valves seals=23.00
set of 32 valve locks=25.00
Super Tech single valve springs=145.00
Super Tech single valve springs with Ti retainers=335.00
Super Tech dual valve springs with spring seats and Ti retainers=415.00
Machine work is as follows, all done by Class One Performance Engines by Terry Thomas
R&R Guides and hone to ID size=88.00
Valve Job-Radius cut seats,2 angle valves as needed, mill deck surface and chamfer chamber's, finish cleaned and assembled, springs installed, seals installed, tips of valves cut to remain in specs=250.00
Line hone cam Journal's-varies by the head=75.00-100.00
All this work can be done or you can pick and choose what you want done. My porting work is 600.00. If you are going to send me your own parts they have to be quality parts and in good shape. PM me with any questions.
**DONOTDELETE**
(Unregistered)
06/30/06 10:31 PM
Re: FS: Head Porting Services
Do you have flow #'s? The porting looks great, and not trying to discredit! But if you had #'s I am pretty sure I am interested.
CO VR4
(Senior Member)
07/08/06 06:28 PM
I could shave in those polished ports
OldHairyBastard
(I take bottom on trannies)
07/09/06 02:55 PM
Looks good and look forward to having you p&p a few heads I need worked on.
**DONOTDELETE**
(Unregistered)
07/11/06 01:26 PM
What machine work is done for $250?
**DONOTDELETE**
(Unregistered)
07/11/06 01:29 PM
Mill the head, three angle valve job, ream the guides after I install them, and fully assembled.
**DONOTDELETE**
(Unregistered)
07/12/06 09:46 AM
Also would be interested. Looks amazing, do you flow bench test them at completion?
**DONOTDELETE**
(Unregistered)
07/12/06 12:19 PM
I have flowed several heads after I have ported them, and all have been very close to one another. To match each port exactly would take forever and would cost quite a bit more. I can however do it if you would like. The cost would be 25.00 to 30.00 dollars an hour and I have no idea of how long it would take, because if I take a little to much out of one then I would have to go take that much more out of the other ports and if on the last port I take to much out I would have to go back and fix the other ones. All in all it really isn't that critical to have each port an exact match. If they are +or- 1 to 2 % I am happy with that. I have had no complaints yet.
**DONOTDELETE**
(Unregistered)
07/18/06 09:54 AM
Re: FS: Head Porting Services *DELETED*
Post deleted by BOOSTIN HARD
OldHairyBastard
08/10/06 04:49 PM
I gave him a set of Toyota heads and an intake to do. I will post pics when it is completed but I told him no hurry so it might not be for a little while.
Doug
OldHairyBastard
08/14/06 11:22 AM
He has already started on one head and brought it over yesterday. It looks really good. If anyone is out there and needs a P&P he is your man to take it to. He is a stand up guy and you will have no issues with BS. What he tells you is what it is and he is ready to work!!!!
**DONOTDELETE**
(Unregistered)
08/24/06 11:11 AM
New parts added.
**DONOTDELETE**
(Unregistered)
09/01/06 10:58 AM
what kind of numbers are you getting?
**DONOTDELETE**
(Unregistered)
09/01/06 11:01 AM
Don't bother asking. There was a HUGE discussion about this. Just search, and you will see you asked a worthless question. Not being a dick either, sorry if it sounds that way!
**DONOTDELETE**
(Unregistered)
09/01/06 11:22 AM
just found the thread. i got a good laugh thanks.
whats the setup the head in those pictures is going on? has it run yet? what kind of power/et? anyspecifics other than 'its shiney' ?
**DONOTDELETE**
(Unregistered)
09/01/06 12:25 PM
42R, 2.3, air to water IC, Driven Innovation intake manifold, No numbers yet maybe in the next two weeks.
**DONOTDELETE**
(Unregistered)
09/01/06 12:38 PM
Yes I do.
**DONOTDELETE**
(Unregistered)
09/25/06 02:56 PM
CmanorVr4
(Member +++)
10/28/06 10:47 PM
PM sent!!!
**DONOTDELETE**
(Unregistered)
11/17/06 02:05 PM
Hertz can you make this a sticky so it doesn't get deleted every month. Thanks buddy
steveGalant VR4.org Administrator
(Key Fob Guy)
11/17/06 02:07 PM
So you were able to get this thread back!
**DONOTDELETE**
(Unregistered)
11/17/06 02:09 PM
I just went back and found it by looking on my last posts. It just keeps getting knocked out of the sticky.
Doctor_D
(Member +)
11/17/06 02:29 PM
pm me more info, need a head ported
CmanorVr4
(Member +++)
12/02/06 06:55 AM
You have a PM!
**DONOTDELETE**
(Unregistered)
06/16/07 04:54 AM
Hey I am interested in how much good it will do to have my 14b ported and if it is even worth the money? Would it be better just to wait and upgrade my turbo when I can afford it... in like a billion year seeing how this stroker build is going to kill my wallet.
**DONOTDELETE**
(Unregistered)
06/18/07 11:01 AM
Its going to gain you some power up top but you would be better off waiting. You aren't going to put a 14b on your stroker are you?
mikus
(weiterhin das Huhn f#$k)
06/25/07 03:17 PM
Re: FS: Head Porting Services NEW DEAL!!!
EDIT - once again I've proven I can't post right :P
**DONOTDELETE**
(Unregistered)
06/27/07 05:37 AM
Naw, the stroker is another project and the 14b is going back on my car. When I took it off to check it out I noticed some large cracks right around the step for the aligning ring.
Picture is not that clear but the cracks are not very deep and I figured if I had some port work to delete the step that might fix the cracks. Like the fat chips it the blades from pieces of ring?
HertzGalant VR4.org Administrator
(OneTitle to rule them all.)
06/29/07 06:54 AM
...unsticking thread, free bump.
**DONOTDELETE**
(Unregistered)
10/23/07 08:22 AM
Porting is up to 600.00 everything else is still the same. My price had to go up about 4 months ago and I haven't had a chance to change it on here yet. Sorry
(Space Blanket from NASA plumbed into the attic)
10/26/07 12:58 AM
free bump
bigblock4g63
(Member +)
03/02/09 11:26 AM
are you still porting and what are the price now ?
(Old Balls)
03/02/09 04:42 PM
He does not come on here much but he does still do this. PM me and I will give you his cell.
03/02/09 04:48 PM
Also has a hard time answering calls. Tried returning his call twice today but I missed the first one so maybe he's trying to be one up on me.
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
