cody
(Member ++)
03/17/19 10:41 PM
FS: Part out 91 GVR4, #597, aftermarket and stock
Due to some major rust issues and a loss of interest I am parting out #597. The first stage of items for sale will be the engine and any aftermarket parts. The shell is currently complete and all items from it are for sale. If you don't see it listed please feel free to ask. Pricing doesn't include shipping, I would prefer pick up for larger items but I can certainly arrange freight. I do accept paypal.
XTD 6 puck clutch and chromoly flywheel. Approx 2,500 miles $125
FMIC vertical flow core, brand unknown. Core dimensions 24x6x3, with tanks 11" tall. 2.5" in/out connections. Will include piping w/ stock blow off valve. Piping was set up for turbo listed below. $250
Honda aluminum radiator. 3 row core, dimensions are 14x16.5x2.75. Includes Spal slim fan w/ shroud. Will include stainless coolant pipes. $200
B&M oil cooler w/ hoses. Cooler dimensions 11x8.25x1.5. $75
Front strut bar, brand unknown. $10
Turbo/exhaust manifold/wastegate. Masterpower T70 turbo, normal shaft play, custom top mount forward facing exhaust manifold. Tial 38mm wastegate. Will include oil feed/drain line and wastegate dump tube. $1000
Mallory AFPR w/ gauge and feed line. Model 4305M. $100
3 Urethane motor mounts. Missing front. Engine timing side was modified to eliminate mount by PS bracket. $30
FIC 750 injectors $125 **SOLD**
4G63T engine. Stock internals. ARP head, main and rod hardware. MLS head gasket. Machined balance shaft. 90 oil filter housing w/ 1/2 JIC fittings. Powder coated valve cover. Approx 2500 miles on rebuild. $1000
3" GM MAF and translator w/reducer couplers to 2.5". Translator is missing cover. Has 2g MAF plug. $50
Voodoo MBC. $10
Non Cruise throttle cable. $10 **SOLD**
Non EPROM ECU $50
Apexi SAFC 2 w/ extension harness and stand. **SOLD**
Adjustable fan control relay w/ temp probe for radiator. $15
AEM wideband w/ sensor and gauge stand. $100
Blitz 60mm electric gauges w/ sensors. Oil pressure in kpa/bar, Boost in kpa/bar, temp in celcius. $100/ea or all 3 for $250.
3G Eclipse wheels with Fuzion Touring 215/50R70 tires. Rims are powder coated a dark bronze. Tires and wheels in good shape, lots of life left, don't have a gauge to measure depth. No center caps. $350
Evo 8 F&R seats. Front seats have brackets to fit into a Galant. Rear seat foam has been cut to fit in Galant. No tears. $400
Lesac
(Junior Member)
03/18/19 08:57 AM
Re: FS: Part out 91 GVR4, #597, aftermarket and stock
what coilovers are on the car? Is the hood in good shape?
cody
(Member ++)
03/18/19 09:27 AM
K-Sport coil overs. I have a friend interested in these, which is why I didn't post them. Should he change his mind I'll post them up. Hood is in decent shape. Some scratches, but isn't rusted under the front lip. I'll get some pictures this afternoon.
Lesac
(Junior Member)
03/18/19 09:40 AM
sounds good, I may need more parts as well. Hows the rear window trim?
idreamidrive
(Member +)
03/18/19 09:45 AM
Front and rear window trims, I really just need the corner pieces.
Rrohde84
(Junior Member)
03/18/19 12:53 PM
do you have a front steering rack
cody
(Member ++)
03/18/19 12:56 PM
Currently has a manual steering rack in it.
cody
(Member ++)
03/18/19 02:06 PM
Checked out the hood, it does have the typical rust under the front lip.
cody
(Member ++)
03/18/19 02:07 PM
Lesac
(Junior Member)
03/18/19 03:17 PM
Thanks for checking, Iíll pass on the hood but still interested in these window trim parts Iím missing.
Terrance362
(needs moar imput)
03/18/19 09:45 PM
I need the non cruise cable
yonwd
(Newbie)
03/19/19 01:16 PM
how much for the manual steering rack? in good working condition?
cody
(Member ++)
03/19/19 01:40 PM
Rack is in good working condition. Its still in the car. $125 + freight. Probably wont get to taking it out till the weekend.
cody
(Member ++)
03/20/19 08:14 PM
All window trim is available and in good shape. Just need to remove it without wrecking it. Will do this tomorrow.
Lesac
(Junior Member)
03/21/19 12:26 PM
Excellent thank you!
cody
(Member ++)
03/21/19 04:13 PM
Got the rear window trim out. $25 +shipping. I'll have to see if the trim will fit in a tube. Not sure about the bottom piece.
Lesac
(Junior Member)
03/22/19 08:23 AM
I only need the 2 parts from my above picture. If anyone else needs the rest of it then have at it.
mscatchell
(Newbie)
04/10/19 09:30 AM
Did your vhl have ABS or did you already delete it? I have a 87 JDM and the pump just started leaking. I'm looking for either a used pump or for the NON-ABS prop valve if you have it. Thanks
cody
(Member ++)
04/10/19 02:55 PM
ABS was removed by a previous owner. I did scrap the shell already and unfortunately the valve was one item I did not remove before hand.
BLUELIGHTSBABY
(Junior Member)
04/17/19 01:51 AM
Do you have the drive shaft and carrier bearings?
Lonewolf64
(Obviously the answer is......)
04/17/19 07:48 PM
How is your driver's side A pillar plastic trim?
(I ain't no puny human)
04/17/19 07:50 PM
Quoting BLUELIGHTSBABY:
You want new carrier bearings, used ones will most likely tear when reinstalling as they would be over 25-year old rubber
vargh4
(Newbie)
04/19/19 04:32 PM
Brake calipers? I'd be interested in all four.
thomasmutter
(Newbie)
04/24/19 10:20 PM
Messaged you about a few parts. Shoot me a text 5412927970. Thank you
Gersonseagle
(Newbie)
04/27/19 03:29 PM
What color is the front bumper? More pics n price? Also the bumper lights available?
91GVR4#479
(Senior Member)
04/29/19 05:05 PM
I need B pillar vertical plastic trim and the horizontal plastic trim that is between the top of the from windows and the headliner.
Do you have them please?
Please also reply to [email protected]
Thx.
cody
(Member ++)
05/01/19 06:37 PM
Sorry guys, have been super busy lately, haven't checked this in a while.
-Drive shaft is still available.
-A-Pillar is sold.
-Front calipers are sold, but I do have the rears.
-Front bumper is sold.
I will try to update the original post since a lot of stuff has sold.
cody
(Member ++)
05/01/19 06:44 PM
Was looking through my PM's and I received one from Tim about my engine. Accidently hit the delete button instead of reply. Engine is sold. Sorry.
Turbocoupe
(Newbie)
05/05/19 04:21 PM
Fuel pump sending unit?
Thanks,
Adrian
1295inthe303
(Newbie)
07/01/19 02:12 PM
PM sent
91gvr4NC
(Newbie)
07/28/19 12:52 PM
PM sent
Stevenoly
(Newbie)
07/29/19 07:21 PM
Hi, looking to see if you have the L/H rear dogleg (trim in front of the wheel well). Also interested in the c-pillar trim (looking to convert JDM car to rear shoulder belts). Shipped to 98275
JamesFoster
(Infamous BMX Master)
08/08/19 12:12 AM
How about the ecu harness?
HollywoodHalo560
(Newbie)
08/09/19 09:26 AM
PM Sent
gs300cky
(Newbie)
08/10/19 10:54 PM
Do you have the main wire harness for the engine bay still?
gonzoe00
(Newbie)
08/14/19 09:46 AM
pm sent
mepicaz
(Newbie)
08/16/19 07:12 AM
PM Sent
AllanL
(Heal and Toe)
09/10/19 06:36 AM
has anyone received any replies to their pm's?
cody
(Member ++)
09/11/19 07:43 AM
Hey guys, sorry I haven't been on here throughout most of the summer. Had a very busy summer. A majority of the parts are sold. I have a lot of messages from a couple months ago. If your still in need of parts let me know and I'll try to keep up with PM's. The shell is gone. I'll update the parts list when I have time.
Generated in 0.015 seconds in which 0.013 seconds were spent on a total of 4 queries. Turbo powered.
