WTB: Need Electrical Connectors
4g6Tree
Active member
Salem, VA
Doing some rehab on #77 and need a few connectors preferably with at least a few inches of wire left on them.
Basically I need a connector for the the CAS and all sensors and switches on the thermostat housing.
• 6 bolt CAS connector
• A/C Coolant Temp Switch connector ( the one on top of the thermostat housing)
• Engine Coolant Temp Sensor
• Engine Coolant Temp gauge unit
4g6Tree
Active member
Salem, VA
That's a good link, I found the CAS connector. But I can't seem to find the other coolant temp sensor/swtich connectors. Mine connectors are long gone so I'm not entirely sure what they look like, or what series they are.
I think you need at least these:
coolant temp
single pin sensor
This one MAY be able to be modified (keying of connector is different) to fit the a/c temp sensor on top of the thermostat housing.
ac temp
