WTB: awd rear trailing arm/hub bearing assy, subframe
Pushinink
cincy, oh
as the title says, after rear trailing arms. prefer semi close to OHIO as I know shipping will be expensive. Must have good wheel bearings and not heavily rusted. Bonus if they already have active toe rubber removed! I would also be interested in the whole rear 1g dsm subframe if someone is local to me (I dont want your galant 4ws subframes)
I have two rear trailing arms, but I believe (have to check) that the rear axles and bearing are removed. Now I believe I also have a set of 4 bolt rear axles if you are looking for those. Bearings may be with them.
BTW, the rear subframes are the same dimensionally. If they are at all different, it is just the tabs for the rear rack tie rod ends, and those could be cut off.
I am in SE Michigan.
EfiniX
portland, or
EfiniX
portland, or
Fair enough. Good luck!
