RedTwo
Anyone got some tips for fitting the big 26mm whiteline rear sway bar?
These universal mounting brackets are pretty weaksauce - they barely line up with the factory holes and then the notches cut into them are about the same size as the M12 head used to secure them! The factory brackets don't clear the bar and GTO brackets don't like up (~6-10mm out).
I've put the 'mighty' C clamps on one side of the bracket and bolted down the other side, similar to the VFAQ but there's still a whole heck more to do to make it fit.
Is there actually a way to bolt it up to the factory mounting points?
