Tuning problems
Having some ECU problems and am looking into getting a dsm link. Will i need to get a new ecu or will the dsm link solve those problems if tuned right?
Well a few weeks back i would flore it and it was stutter and not hit close to full boost and just chatter, not fuel or boost cut and i pulled a check engine light. disconnected battery and didnt have the problem again then a few days later it happened again and it hasnt happened since so i think something is wrong in the ecu.
Did you pull your codes when the light came on? Cause you could have a simple problem that's intermittent. You should diag your problem before rushing into a conclusion then putting link in it and still have the problem.
